2010 2011 BMW 5 Series Forum F10 Considering 535i Larger Turbo |
07-17-2018, 08:44 PM | #1 |
Rep 11
I am pretty close to pulling the trigger on getting a 2013 535i xdrive. I plan on getting a Pure stage 2 kit right off the bat, although I haven't seen a lot of info on putting them in the 5 series. Is it much different than a 335, procedure wise? I would have thought there would be more working room in a 535 than in a 335 or 135. I know the Xdrive makes it more complicated, but I have seen at least of few 335 xdrives with larger turbos than stock. Anyways, I was hoping to see if someone on here has experience doing the swap
07-17-2018, 09:00 PM | #2 |
Rep 1,214
335 is honestly a bit easier, have done and seen both done.
xDrive just makes the job suck bigtime, and take a whole lot longer. on xDrive vehicles the engine gets supported from a cross bridge above and the whole front drive and subframe gets dropped down to make the room. Get a RWD car if at all possible, they drive a lot nicer and are easier to work on and keep up with less shit to wear out. |
07-18-2018, 05:24 AM | #3 |
Rep 5,140
07-18-2018, 03:56 PM | #4 |
Rep 11
Well, the main reason I plan to get it is because of the AWD. I would probably go with something else if RWD was an option. If I had a 2 post lift I would be more confident about dropping the drivetrain by myself, with my scissor lift it is going to be a bit harder. Stuck, I saw you had a kind of write up for this, do you have any pictures of dropping the subframe?
08-13-2018, 02:04 AM | #8 |
Rep 332
Yes, I run with Bootmod3.
2022 G82 M4 - Isle of Man Green w/Kyalami Carbon Bucket Seats - MST Intakes, SSR Downpipes, JB4, AWE Exhaust.
2013 F10 N55 (535i), Pure Stage 2, Fuel-It PI Platinum, Fuel-It Stage 2 LPFP, BootMod3, Custom Turbo Inlet, Custom Cary Jordan Tune, More.. SOLD! 1999 e36 M3 - Estoril Blue - Track Car - S54 Swapped |
jayster0966209.00 |
08-20-2018, 11:56 PM | #10 |
Rep 332
Stock turbo with supporting mods and tune should get you near 350-375 RWHP, with Pure Stage 2, around 450 - 500 RWHP. I will have my car back on the dyno in the fall when ambient temps are lower. I dyno'd last fall at 445HP/498 Ft/Lb but I have a better tune and a proper inlet now.
