2010 2011 BMW 5 Series Forum F10 Fitment Question: 20x9 ET20 and 20x10 ET25 on F10 M-Sport |
07-11-2017, 07:14 AM | #1 |
Rep 1,760
I need to get new tires for my stock 19 Ms but I am considering purchasing a wheelset from someone instead. Need some help confirming that this will be a good fit.
The standard specs for 20s on an F10 5 series looks to be: Front: 20x9 ET35 Rear: 20x10 ET40 The wheels that I would be looking at purchasing has the following specs: Front: 20x9 ET20 with 245-40R20 tires Rear: 20x10 ET25 with 275-35R20 tires If I am reading the image below on how offsets work, having a lower offset would mean that the wheels would sit closer to the edge of the fender producing a "flush" look. My question is...is -15 in the front and rear too aggressive of a reduction in offset? And do the tire specs seem good? Do you guys see any major fitment issues with this? And what does programming a TPMS entail? Is this something a BMW dealership has to do and if so, how much does that cost? I thought the vehicle would just recognize the TPMS system installed on the wheels as long as they are the right year. I believe this was for a 2009 750li and I have a 2011 550i
2015 BMW X5 35i M-Sport (White/Brown) - 4/16/18 (Current)
2011 BMW 550i M-Sport (Jet Black/Cinnamon Brown) - 4/30/14 | 2007 BMW 328xi e92 (Jet Black/Coral Red) - PAST | 2005 Infiniti G35 Coupe (Ivory White/Stone) - PAST | 2005 Acura TSX (Obsidian Black/Black) - PAST | 1998 Acura Integra (Black/Black) - PAST Last edited by virtualbong; 07-11-2017 at 07:54 AM.. |
07-11-2017, 08:30 AM | #2 |
Rep 29,202
I assume you've got the staggered 19". They're 19x8.5 ET33 and 19x9 ET44.
This means that the 20x9 ET20 will stick out 19mm more, and that's quite a lot, and will stick out passed the fenders. The rears 20x10 ET25 will stick out even more, 32mm. This will also stick out passed the fender. The tires are also larger, since the profile are 40 and 35, should be 35 and 30 on staggered 20s for the F10.
07-11-2017, 09:29 AM | #3 | |
Rep 1,760
2011 BMW 550i M-Sport (Jet Black/Cinnamon Brown) - 4/30/14 | 2007 BMW 328xi e92 (Jet Black/Coral Red) - PAST | 2005 Infiniti G35 Coupe (Ivory White/Stone) - PAST | 2005 Acura TSX (Obsidian Black/Black) - PAST | 1998 Acura Integra (Black/Black) - PAST |
07-10-2018, 08:12 AM | #4 |
Rep 3
Drives: 2014 BMW 550I
Hey so I have a 14 550i and I purchased a set of rohana rf1’s 20x10 et25 and 20x11 et40... will I have fitment issue? What tire set up should I go with
07-22-2018, 06:43 AM | #6 |
Rep 29,202
20x9.5 ET40 in the rear is fine.
