2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications cant reset steering angle sensor
      11-06-2024, 08:50 AM   #1
f10rico
Drives: f10 535i
2015 535i f10
recently had my steering shaft disconnected and allowed my steering wheel to free spin, dropped the car and turned it on and got a chassis stabilization error, everything on my steering wheel continued working but i couldnt reset the SAS. got a used szl and coded it through E-sys then tried to recalibrate my SAS and still nothing, everything on my steering wheel works. should i grab another SZL and repeat? or is there something else i should try?
here are the codes im getting
      11-06-2024, 10:44 AM   #2
jaysone90
Drives: E90 (2006 330i)
did you replace the full pinion with eps? its says its not coded which means that its not the same as expected. You need
to code eps with esys or ista p 1.61 with enet.
      11-07-2024, 08:08 AM   #3
f10rico
Drives: f10 535i
im only getting one code from my eps, but thats regarding the steering angle
      11-07-2024, 10:01 PM   #4
Hoa
Based on your codes, you might have a bad SZL (clock spring)
      11-08-2024, 01:13 PM   #5
f10rico
Drives: f10 535i
i was thinking that, probably just got a bad szl or the parts store somehow did the same thing i did when they gave me the new szl. ill go back and get a replacement or refund and try again. thanks
