2010 2011 BMW 5 Series Forum F10 Coding retrofit NBT EVO headunit |
11-25-2024, 01:17 AM | #1 |
Rep 99
Hi all! I did NBT EVO headunit retrofit on my car 4 years ago, the original factory equipped was NBT ID4 headunit. I was told that if I wanted to code the NBT EVO headunit, I had to use OABR cable together with Enet cable or Enet cable over OABR cable converter modified in the quadlockd, otherwise the headunit cannot be detected. Is that true?
BMW F10 LCI 520i RHD from Hong Kong
11-27-2024, 02:09 AM | #2 |
Rep 99
Hi all! Any idea about this? I found a website describing the OABR cable connection to quadlock:
https://naviandbmwparts.com/blog/new...nd-instruction Is this applicable to my F10LCI? Furthermore, I checked the FSCstatus of my retrofit EVO headunit, found that it was under a different VIN, just want to know if I can flash the retrofit headunit using the OABR cable via esys and had the VIN corrected to my VIN. Thanks for help!
