2010 2011 BMW 5 Series Forum F10 GPS navigation going the wrong direction |
11-22-2024, 09:06 AM | #1 |
Rep 99
Hi guy! Recently my car's GPS navigation has a problen pointing to the wrong direction. When I drive north, it goes north west, the farther I drive the farther wrong way it goes. I searched the forum and saw a discussion mentioning a guideline issued by BMW how to use ISTA to calibrate the GPS. I will give a try to see if the issue can be solved, it not maybe I need to change the GPS antenna. My headunit is not factory installed NBT ID4, I upgraded it to NBT EVO ID5/6 and using an aftermarket GPS antenna as my car did not come with navigation professional option. I guess probably the aftermarket GPS antenna goes bad. Any idea/experience you guys can share? Thanks!
BMW F10 LCI 520i RHD from Hong Kong
11-22-2024, 09:13 AM | #2 |
Rep 1,629
Did you use this to connect your GPS antenna? It is required to get signal from your trunk to your head unit when going to EVO
Bingfu Fakra Z Female to Male... https://www.amazon.com/dp/B07PHW5SBP...p_mob_ap_share |
11-22-2024, 10:37 AM | #3 | |
Rep 99
11-22-2024, 10:42 AM | #4 |
Rep 1,629
Either that antenna is defective or it’s location is a problem. Try putting it up near your roof to see if it help. I would try the wire conversion method. That way, you don’t have extra hardwares in the car and it’s mounted high from the factory.
11-22-2024, 11:29 AM | #5 | |
Rep 99
I could not find any workable method in ISTA to recalibrate the GPS, I also noticed the guideline issued by BMW was in 2013, it is absolutely obsceleted. No work out.
11-22-2024, 12:36 PM | #6 | |
Rep 1,629
11-23-2024, 05:20 AM | #7 |
Rep 99
Thanks for help! Just for update, I today replaced the GPS antenna with a new one bought from Taobao, and the issue still stays. I noticed that the GPS sometimes can correctly position where I was when I started my car before drove away. Then it wrongfully went in wrong direction, like I was going north it went west and kept going that way. When I turned the wheel it also followed but in the wrong direction. Now I think it is not anything to do with GPS antenna as I put the antenna just below the dashboard under the center speaker trim cover (I don't have center speaker in the dashboard), it should be receiving signal very well in that location. As it keeps going wrong direction, now I think it probably has something to do with compass that is integrated in ICM. However, there is no fault code in ICM, so I think it is possibly a coding issue or I need to change setting in ICM FDL coding. Any idea? Thanks!
11-24-2024, 05:45 AM | #8 |
Rep 99
Just an update: Today I FDL coded KAFAS to CAM only from fusion, then the navigation came back to normal. Therefor I think something messed up the navigation by the fusion setting in KAFAS.
