07-14-2021, 10:07 PM | #1 |
Rep 4
N63 downpipes no cel
Installed a set of VRSF downpipes about 2000km ago. Didn't want the trouble to install a JB4 so I use a 90 degree o2 mini cat from Amazon.
https://www.amazon.ca/gp/product/B07...?ie=UTF8&psc=1 No cel after driving in city and high way. No pending codes either. |
08-07-2021, 12:00 AM | #5 |
Rep 4
Removing the oem cats is not fun. Remove the skid plate to get better access to the heatshield bolts.
Also I'm nearing 5000km's and catalyst efficiency popped up, the mini cat material is chipping away fast. I assume it can't handle the heat. |
08-16-2021, 12:49 AM | #6 |
Rep 262
I would recommend finding a way to hide it all under the heat shield because during your emissions they will fail you if they do the visual check.
Before I had my tune I was failed due to visual, I had my heat shield on but not the engine cover. With the heat shield and engine cover it hides them much more and catch cans help out that much more to conceal it all. Just some advice for those about to go through emissions.
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
