2010 2011 BMW 5 Series Forum F10 F series footwell light upgrade |
10-20-2021, 04:40 PM | #1 |
Rep 3
I recently bought from R44Performance, a small company based in the UK, some LED front footwell lights for my LCI F10. The parts are supplied from the US.
When I fitted them I found that when I selected Classic (orange) in iDrive, the new footwell light turned white, (the rest of the ambient lighting was correctly orange), and when I selected Modern, it turned orange - ie the coding is the wrong way round. R44 is contacting the US suppliers but the guy I spoke to seemed to think there might be an issue over the white light being called Modern/Sport in different cars, but to me Classic is orange no matter what the white light is called. Has anyone experienced a similar issue or is there a solution to this? I believe these lights should fit all F cars with the Classic orange Modern (Sport) white ambient lighting choices. Many thanks |
10-21-2021, 06:53 AM | #4 |
Rep 3
I've checked the new part with the OEM part. The plug has to be rotated 180 degrees to fit into the new part, which then swaps the colours around. Puzzling. I can't see why that has been done or how to get around it!
10-21-2021, 08:23 AM | #5 |
Rep 20
Just switch pins in connector. I got from China RGB replacement strip and I had to switch two pins for R and G in connector. What to say, cheap replacement and no quality control at all.
Best regards Borut |
10-24-2021, 02:18 PM | #6 |
Rep 2,637
Yep, just pop the pins out and reverse them. Had a similar issue with aftermarket sequential turn signals in the mirror.
2015 BMW 535xi
