2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums F10 / F11 5-Series Photos - Video - Media What did you do to your 5 series today?
      10-13-2025, 04:37 PM   #3851
poverty.f10
Semi-Feral Mechanic
poverty.f10's Avatar
180
Drives: 2012 BMW 535i xDrive
Decided to fix my screen. Next is a MMI box for CarPlay.
You can live in a car but you can’t race a house.
NikMN4433.50
zrile186.00
      10-14-2025, 10:21 AM   #3852
kskamser
kskamser's Avatar
Drives: bmw f10 535i
1998 bmw 323i  [10.00]
2014 bmw 535i  [10.00]
Originally Posted by addy27 View Post
And here is how BMW_Alpina’s Honey Walnut trim looks in my Individual Platinum interior:
The best trim you could get congrats! If you sell eventually let me know. I couldn't find a set when I was looking to replace my trim.
      10-14-2025, 10:29 AM   #3853
addy27
Drives: F10 550i
BMW_Alpina is the owner, it will be his decision. We’ve basically exchanged our trims as he’s been looking for the Alpina trim for years and I wanted to see how closely the honey walnut + Platinum matched to the bmw individual press F10 car back in the day.. ☺️
      10-15-2025, 02:38 PM   #3854
zener
BMW enthusiast since 2004
798
Drives: E65 730d, F10 520d, E34 520i
Showing some sings of winter so put winter tires on and lifted it a bit.
      10-15-2025, 10:12 PM   #3855
jared21927
Drives: 2016 550i
Originally Posted by BMW_Alpina View Post
markivvv Don't forget the trunk LED replacement ($11 on Amazon)
Where did you get this spare? Seems like something good to have
      10-17-2025, 11:00 AM   #3856
kskamser
kskamser's Avatar
Got my valved mufflers and dual tips installed! The tips do poke out a tad bit more than I’d like but it required a lot of custom fabrication so I can’t complain too much.
NikMN4433.50
dimaka_77196.00
      10-17-2025, 02:47 PM   #3857
zrile
zrile's Avatar
Croatia
186
Drives: BMW F10 520d
Well.... i got stage 1 on my 520d, and it was not good so i reverted to stock....car got 237hp and 470 Nm torque. But, lost 8th gear, car got to 215 kmh and stopped, as there is no one more gear, even with manual shift, it would just go back to 7th. So i reverted to stock. Wanted to go find another tuner, but instead got new rims from a friend, style 94 from 7 series for summer set. I have new summer tires, and tpms sensors allready waiting for installation. They need a bit of love, so i have few months to fix them. Few small dents from road, but inside is terrible. Looks goooood on a car.....
      10-18-2025, 03:42 PM   #3858
zener
798
Replaced drivers door outer handle cable. Old one started to play funny with freezing conditions.
zrile186.00
      10-18-2025, 08:42 PM   #3859
dimaka_77
dimaka_77's Avatar
Drives: BMW 550i
Finally nailed my perfect sound setup 🔥
I’ve had OEM M5 mufflers on my 550i for a while now, but always wanted a bit more tone — especially on cold start. This week I finally went for it and deleted the silencers + big center resonator, replacing them with a Borla X-pipe (PN 621105).
The sound is exactly what I was after — not screaming loud or raspy, just deep, clean, and refined. Valves closed it’s totally calm, but when I open them it comes alive with that deep V8 growl and turbo whoosh. In Sport mode around 2.5–5k rpm it absolutely sings, and with my Mission Performance Stage 1 and XHP Stage 2 trans tune, it gives those obnoxious pops and bangs in Sport that are almost too embarrassing ��
Current exhaust setup:
• OEM F10 M5 mufflers w/ valves + Valvetronic controller
• Borla X-pipe (PN 621105) replacing resonator + silencers
Perfect balance of tone and refinement — zero drone, tons of character. Couldn’t be happier with how it turned out ��
For anyone interested here is the video of the cold start: https://photos.app.goo.gl/fLox535P5QCKa4YE8
      10-22-2025, 10:57 AM   #3860
zrile
zrile's Avatar
Croatia
186
Give us a video with sound!😃
      10-22-2025, 11:01 AM   #3861
dimaka_77
dimaka_77's Avatar
Drives: BMW 550i
The link to the video attached to the original post. Lmk if it doesn’t work.
Attaching here as well: https://photos.app.goo.gl/fLox535P5QCKa4YE8
zrile186.00
NikMN4433.50
GS535i0.00
      10-22-2025, 02:15 PM   #3862
zrile
zrile's Avatar
Croatia
186
Hohohoho!😃🤌🏻
      10-24-2025, 07:03 PM   #3863
Migelito
Migelito's Avatar
Drives: 535xi 2015
did bootmod3 Stage 1 Octane 93
I just flashed bootmod3 stage 1/93 and it rocks!
finally got a 5 series...
dimaka_77196.00
NikMN4433.50
      10-27-2025, 08:46 AM   #3864
markivvv
Drives: F10 535i M Sport
Thoughts so far? I'm on the fence
      10-31-2025, 01:51 PM   #3865
s_ribs
Drives: '15 535i xDrive M-Sport, E30
Had an interesting experience last weekend. Weather has been getting cold enough that I decided to swap back to stock wheels with winter tires. That was easy.
Needed to change my oil, which is also easy. I planned on giving my car a good cleanup afterwards, and went to reposition my car. After the cold start sequence ended it started running horribly and a drivetrain malfunction popped up on the screen. Of course this happened at 3pm on a Saturday and I needed to drive to the airport an hour away for a work trip the next morning.
I had two codes:
131401 - VANOS, exhaust, cold start: not adjustable
120408 - Boost pressure control: shutdown as a follow-up reaction
ChatGPT gave me the exact sequence of items to check.
  1. Make sure the oil filter cage wasn't missing. I knew it wasn't but I checked, and even replaced the filter just to be safe.
  2. Remove and clean the exhaust VANOS solenoid. (I opted to skip this as I would need to buy new seals and the cost wasn't much more for new solenoids)
  3. If cleaning didn't resolve the issue the replace the solenoid.
I ordered a new solenoid from RockAuto ($25 each) while at my hotel room on Sunday night so they would be delivered while I was gone. Came back Wednesday afternoon and swapped out the solenoid for the new one. Problem solved! Guessing it was on it's way out and this was a random coincidence that it died after changing the oil. Either way it was a cheap and easy fix so all good. May replace the intake solenoid as preventive maintenance as I ordered 2.
And yes,
      11-08-2025, 03:09 PM   #3866
NikMN
NikMN's Avatar
Drives: BMW 550i
2015 BMW 550i   [9.25]
Time for winter wheels
      11-08-2025, 08:22 PM   #3867
bk_mike
bk_mike's Avatar
Drives: F10 550ix
Winter wheels and a quick wash since its still warm out...
NikMN4433.50
      11-11-2025, 02:03 PM   #3868
JonnyRock
JonnyRock's Avatar
54
Drives: '14 535d Msport
For my birthday this last weekend, I bought DUDMD's Stage 1 tune and flashed my 535d. Quoted roughly +80hp and +100tq. Have only stomped on it a little this morning but so far so good!
In the next week or two I hope to tackle finishing my BBK upgrade too!
      11-22-2025, 11:35 PM   #3869
Carbon535i
Carbon535i's Avatar
Drives: 2015 BMW 535i xDrive M sport
Installed three Ultra Racing rear 2 Point braces recently.
NikMN4433.50
s_ribs134.50
      11-29-2025, 01:05 PM   #3870
beeman1
Drives: 535d F10
I'm looking into DEF/EGR delete and tune? F10 535d for offroad use. Any Known Reputable Vendors?
      12-05-2025, 12:17 AM   #3871
JonnyRock
JonnyRock's Avatar
54
Delete would be a Stage 2 tune, from either DUDMD or Malone/Tunezilla. After researching, I went with DUDMD. I haven't deleted yet so I'm using his Stage 1.
      12-06-2025, 03:32 PM   #3872
JonnyRock
JonnyRock's Avatar
54
Busy over the break
Spent Thanksgiving break tackling a few items on the D. Completed the following:
  • Air filter
  • Cabin air filters
  • OEM mud guards
  • G11 front caliper & rotor swap
  • M5 rear caliper & rotor swap
  • Winter wheels & tires swap
Felt good too get so many things done. Next up will be fuel filter replacement.
s_ribs134.50
dimaka_77196.00
