2010 2011 BMW 5 Series Forum F10 DIY: 8HP Transmission Fluid Service |
02-23-2024, 02:19 AM | #89 | |
Rep 2,595
Thank you for bringing Step 4 to my attention, I had neglected to update that step to reflect the ZF information. You should NEVER release your foot off the brake.
2015 BMW 535xi
Blue Angel1036.50 |
02-24-2024, 10:50 AM | #90 | |
Rep 64
Diff fluid on a RWD 550 is just drain and fill correct? |
02-24-2024, 11:27 AM | #91 |
Rep 2,595
Yep nothing fancy. There's no drain plug IIRC so you need to figure out how to suck out the fluid. I used thin poly tubing to mine out.
2015 BMW 535xi
ChiltiCoatl891778.00 |
03-15-2024, 11:04 PM | #92 |
Rep 439
Drives: 2016 F10 BMW 535i M Sport
I deeply respect the attention to detail in making this for all of us to use! I want to do this myself, I have the tools for it, I know my 5er will greatly benefit from a drain and fill.
03-15-2024, 11:13 PM | #93 |
Rep 5,396
One big reason I don't do this is the need to keep the car level. I'm also not young enough anymore to do all this work lying on my back.
03-17-2024, 03:39 AM | #94 |
Rep 439
04-18-2024, 06:20 AM | #96 |
Rep 123
Good write up. Bout to do this after I swap coil packs, spark plugs, water pump, and front brakes. Sitting at 53k miles.
2012 F10 535ix - JB4 - BM3 - Meisterschaft GTC - coded modules - CF front lip - CF rear diffuser - clear bra
