2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Car runnning EXTREMELY rough after throttle body adaption reset
      05-01-2019, 01:59 PM   #1
partymartyy
partymartyy's Avatar
Drives: 11 535xi
Hello everyone.
My car has been running a little rough here and there during idle.
Brief backstory: My 2011 535xi was throwing codes p306d (misfire on cylinder) and p112f (MAF).
90k miles
I replaced the MAF, and engine airfilter. Still have CEL, but the rough idle is nearly gone.
A few weeks go by, idle pretty normal now.
(https://www.e90post.com/forums/showthread.php?p=6309845)
After reading multiple posts, I try to do the throttle body adaption reset.
Immediately after doing the reset, my car is shaking HORRIBLY at idle. I don't even want to drive it... The car is jerking extremely hard and RPMS are fluctuating from 500-1500. Previously, I'd say the idle was a 2/10 on a scale of 10 being horrible. Now, after the throttle reset, its a 10/10.
When popping the hood, I notice my pulley is shaking like crazy.
Could this be a software issue? Will this go away if I drive for a few hundred miles? Should I replace the throttle all together?
Thanks....
      05-01-2019, 02:40 PM   #2
Surly73
Drives: '11 535xi 8AT KWv3 MPE MHD xHP
It just popped into my head that I read once that after doing one of the adaptation resets, it may have been throttle body or valvetronic, you need to shut off the ignition, wait, turn on the ignition WITHOUT starting the engine and WAIT, then start the engine. If you don't, you have trouble. Your story sounds like trouble.
Might be worth trying another reset but with more waiting at each stage - like 30s?
      05-01-2019, 03:04 PM   #3
partymartyy
Drives: 11 535xi
Tried it again.. unfortunately no success.. I read my CEL, found codes P112F, P306d, and P115d... No surprise from the P112F, but could simply resetting the throttle cause p306d and p115d? Just seems crazy...
      05-01-2019, 03:09 PM   #4
wcr3d
Drives: 2013 535i XDrive M Sport
You really need a bmw specific scanner.
Also CEL are emissions related warnings.
      05-01-2019, 03:10 PM   #5
partymartyy
Drives: 11 535xi
Going to dealership tomorrow.. I will update with any information
      05-02-2019, 07:06 PM   #6
HizEternal
Drives: Jet Black F10 535XI
I may have read it wrong but you also had a misfire and decided doing a throttle body reset was a good idea before diagnosing the misfire? Seems that’s what lead to your trouble. The engine already had a timing problem and you decided to put it in learning mode during that problem. Fix the misfire and I’m sure it will properly learn the throttle body position to run smoothly again.
      12-13-2019, 04:42 PM   #7
superlazy
Drives: 550xi, Z3 3.0
What was the result? I got a P112F code yesterday.
