2010 2011 BMW 5 Series Forum F10 ACS possibly causing tire cupping |
05-10-2013, 08:33 AM | #1 |
Rep 177
My front tires are cupping http://www.ehow.com/about_5509983_ca...ing-tires.html. They are a lot of factors I understand. But has anybody have any problems yet with the ACS springs? I have Dunlops SP Sport 9000. I always drive in Sport mode so the suspension would be a bit taut. I know if I take it to the dealership they are going to blame the Springs! I dont want to spend another 1000.00 to take them off. Anybody in MO closer to IL can help take them off?
Thanks |
05-10-2013, 12:47 PM | #4 |
Master Of My Domain
89
Rep 669
Sometimes low air pressure will cause cupping. What pressures are you running?
RIP: 2015 Black Sapphire Metallic 650i Gran Coupe, 343 Wheels, Michelin Pilot Super Sports 255 F / 285 R, M6 Front Grilles. Coming - M6 Comp. Mufflers, Carbon Fiber Diffuser & Spoiler.
05-10-2013, 03:37 PM | #6 |
Rep 177
05-10-2013, 09:06 PM | #9 |
Master Of My Domain
89
Rep 669
05-11-2013, 09:56 AM | #10 |
Rep 937
Front pressures do seem high. Also, rear pressures are a couple of pounds higher than fronts. I'd take the fronts down to 38 or so, and keep the rears around 40.
05-11-2013, 10:24 AM | #11 |
Rep 177
I'll try that out for a week or two and see if that will help. Is this the correct numbers for the ACS front and rears? Front 3133 210 410, rear 3353 210 410? I just want to make sure that it was installed correctly!
05-11-2013, 11:02 AM | #12 |
Rep 585
I run my front 245/35/20s at 55 and my rear 285/30/20s at 45. Of course I've had to replace my rears from hard acceleration from my Dinan Stage 2, but no cupping and the fronts have very little even wear at 26k miles on my Michelin PS2s. I've found after having many BMWs that the fronts will last twice as long if you over inflate them since they typically wear out on the outer and inner sides first. I have a little outer and inner wear from the mileage but no center wear from over inflation.
