07-09-2021, 12:08 PM | #485 |
Rep 1,299
07-09-2021, 12:09 PM | #486 |
Rep 104
07-09-2021, 12:11 PM | #487 |
Rep 1,299
I did not find any pure performance benefit going aftermarket intake vs just drop-in filter... my wastegate duty cycle still remained the same and surprisingly drop-in filter made throttle better and smoother.
07-09-2021, 12:15 PM | #488 |
Rep 104
Hmm, I guess I can save some money by just going back to stock intake with drop in filter. I will try it and do some logs.
07-09-2021, 12:23 PM | #489 |
Rep 1,299
07-09-2021, 12:33 PM | #490 |
Rep 104
I made 520ish RWHP with 18 psi full e85. I need to get back on the dyno with 20 psi to see what she does now. However, I had my timing backed down 2 degrees or so since making 20 psi.
PS2, Wagner FMIC, XDi-60, Fuel-It! Stage 2 LPFP, Mperformance Mufflers, BM3
07-09-2021, 12:41 PM | #491 |
Rep 1,299
I am going to dm you with my email.. can you please send me the log file of when you making 520ish rwhp on 18psi?
07-09-2021, 12:53 PM | #492 |
Rep 1,440
Drives: 2011 535i 6MT
My comment is made in context of my previous post - meth increases fuel rail pressure which allows you to run full e85.
07-09-2021, 01:17 PM | #493 |
Rep 1,299
07-09-2021, 01:18 PM | #494 | |
Rep 1,440
07-09-2021, 01:20 PM | #495 |
Rep 1,440
That's what DS said - I am gonna trust him and I want meth anyway!!! MHD has some cool stuff with their new e85 integration to the ecu - we'll be full flex fuel ready and tune switching on the fly!
07-09-2021, 01:39 PM | #496 |
Rep 1,299
Maybe meth puts less demand on the fueling so the hpfp doesn't have to run as much volume when combined with meth.
07-09-2021, 01:45 PM | #497 | |
Rep 1,440
Plus it is extra fuel too, don't forget that!! |
07-09-2021, 01:54 PM | #498 | |
Rep 1,299
07-09-2021, 05:56 PM | #499 |
Rep 1,440
Things always break, that's the name of the game. Anything else could just as easily fail. The 2.5 however does come with digital readouts warnings of clogged or unplugged lines or low levels. I'm comfortable with that, plus there are built in DME safeties for low pressure in the fuel rail, auto retardation of timing with detonation, knock sensors, etc etc.
In my mind it just comes with the territory and it's not any less safe than PI with modules and extra pumps, lines, injectors etc that are also points of failure. I guess my point is if you wanted it to be reliable you shoulda kept it stock :-D |
07-09-2021, 07:06 PM | #500 | |
Rep 1,299
07-10-2021, 06:31 AM | #501 |
Rep 1,230
Meth comes in 2 forms. 1 for cooling which is 50/50 and one for fueling. You increase the octane using the form for fueling which produces less stress on the hpfp side but it also comes with its downfalls. Clogged nozzles.. leaky check valves etc. All determining factors to blowing up a motor quicker than port injection with motiv reflex. You can be running a tune designed to use with meth for fueling. Have a clogged nozzle and blow up. I have had 2 clogged nozzles thus far. 1 with pro meth and 1 with cooling mist. I only use meth for cooling now. For fuel its super corrosive and not taking care of starts turning into rust then into your motor. Also leaky check valves is another downfall. If they are left stuck after the car is shut or below the crack pressure then you will have meth leak into your motor and flood it upon start up. Be careful.
07-10-2021, 11:29 AM | #502 |
Rep 1,440
What kit did you have? Did you have the gauge that monitors flow and advises of leaks/clogs?
07-10-2021, 12:52 PM | #503 |
Rep 1,230
True. More E85 you use. The harder it is to stabalize the rail pressure and keep it happy.
N55 GENERAL
David Shoup Tuned Fully Built By Miami Engines/Project Motorworks Precision 6266 On Steroids |
07-10-2021, 01:02 PM | #504 |
Rep 1,230
I had a torqbyte-cm5 initially. Very complex setup but the best out of everything. Monitors and shuts down everything while putting the system into safe mode. I sold it, got rid of meth entirely. Revisited the meth system due to hot temps up here in NY and needed cooling. Went and got the VC2 by Snow Performance. Started playing around with M1 for fuel additive. Went on the dyno and me and David couldnt even tune right since needing more fuel. Stuck at 20psi. This is with FX-180, -10an fuel lines, hellcat LPFP. Wasted 3hrs on the dyno. After going home went over my fuel system and found out my Pro-Meth Nozzle was gunked with rust from the M1 sitting. Went and bought me a Devils Own Nozzle and been good so far. No guage can monitor if there is a clog in the line except for torque byte. For the leaks, if you buy a check valve over a solenoid you cant monitor the cracking pressure. Devils own is the only valve on the market with a 10psi crack pressure i believe. The rest open up at around 20psi. You can always opt for a solenoid and hook it up to your guage but those are 100% more liable to stay stuck open and leak when the car is off overtime.
N55 GENERAL
07-10-2021, 01:03 PM | #505 |
Rep 1,230
If your looking for more fuel to push that turbo i would look into buying a motive reflex and port system till Nostrum figures out the fuel tables for there injectors (mhd N55). You will be running through M1 or whatever fuel you use for that tank like water. $$$. Its the easiest way out of the 2 to make your motor go boom unless your using a reflex or torqbyte to control the meth. Plus you will have to go over your system monthly and purge out all the lines to make sure they are free from gunk and flowing right. Port you dont have these issues. Buy a motiv reflex. David has the base maps for it and let him tune the maps. He taught me how to do mines and pretty easy. The reflex will detect any mishaps and shut the system down immediately with a code instead of leaving you blind plus you can monitor everything from your phone. Eventually to push 600hp plus we wont need these stuff once Nostrum gets there act right with there injectors.
N55 GENERAL
David Shoup Tuned Fully Built By Miami Engines/Project Motorworks Precision 6266 On Steroids Last edited by $howtime456; 07-10-2021 at 01:11 PM.. |
07-10-2021, 01:15 PM | #506 | |
Rep 1,299
