2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Funny noise from exhaust? - 2011 535i xdrive 86k miles.
      08-14-2018, 05:17 PM   #1
BurrNinja
Only hear on longer drives when im getting home or in park with the car on. Video doesnt do crazy justice its slightly noticable within seconds of video. It happens randomly cant ever get a good recording, but heres the link. Any help appreciated.
      08-14-2018, 06:00 PM   #2
NinetyEight740
NinetyEight740's Avatar
Drives: 2 - 2013 535i msport
2010 E91  [0.00]
That noise is not from your exhaust. When it is making the noise, open the oil cap and see if the noise goes away or if it’s hard to remove.
      08-14-2018, 06:05 PM   #3
BurrNinja
Will have to try that, it comes and goes only when up to operating temp around 240ish oil temp. Possible breather hose ? or pcv. Also pulled oil cap off during idle, it dropped in idle had crazy suction holding it down.
      08-15-2018, 12:42 PM   #4
BurrNinja
Will harder suction from oil cap be a pcv problem?
Instgram @burninja
      08-17-2018, 03:30 PM   #5
Surly73
That would be conventional wisdom for pre-Valvetronic engines. Remember that there is no manifold vacuum in a Valvetronic engine and any needed vacuum is generated by a vacuum pump. Personally, I'd still walk down the PCV/CCV diagnosis path if it were mine, since high vacuum should not build up with a properly functioning CCV even with Valvetronic as far as I know.
      08-17-2018, 03:35 PM   #6
BurrNinja
I will replace the pcv hose first as its the cheaper route, i dont hear that squealing all the time its random. Just that huge suction, so far no miss fires just typical idle jumping on cold start idle smooths out 4 to 5 seconds after.
Instgram @burninja
      08-17-2018, 07:38 PM   #7
NinetyEight740
2010 E91  [0.00]
Don’t replace that Pcv hose, that’s not the issue.
      08-17-2018, 07:39 PM   #8
NinetyEight740
2010 E91  [0.00]
Exactly, proper functioning. Which is why I’m asking what I’m asking.
      08-17-2018, 07:42 PM   #9
BurrNinja
What could i possibly start diagnoising, and how id go about it? Im here to learn as much as i can about my car, i enjoy working on them, and trying to diagnose problems before they cause to much of one.
Instgram @burninja
      08-18-2018, 03:31 PM   #10
NinetyEight740
2010 E91  [0.00]
You start diagnosing by doing exactly what I told you. Remove oil cap while it’s doing it and see if oil cap is difficult to remove and if the noise goes away.
      08-18-2018, 04:57 PM   #11
BurrNinja
You start diagnosing by doing exactly what I told you. Remove oil cap while it's doing it and see if oil cap is difficult to remove and if the noise goes away.
Ill have to run out of my car when it happens havent heard for the passed few days. Its random.
Instgram @burninja
      08-18-2018, 08:53 PM   #12
BurrNinja
noise is gone before i get hood open no time to check it still in idle.
Instgram @burninja
      08-19-2018, 04:06 PM   #13
BurrNinja
So i remember my e90 had the same built in pcv system on the valve cover i tested it by blowing air through a tube which let air in constant. Just tested this theory on my f10 n55 which let no air in not like the e90 if similar system. Tried blowing smoke didnt notice any going in at all. Im assuming the pcv system is doing its job right and this sound im hearing isnt anything in relation to the pcv/ccv system.
Instgram @burninja
      08-23-2018, 09:07 PM   #14
BurrNinja
Update.
So after all my research and findings come to conclusion its the rear main seal going out, havent lost any oil knock on wood. Gonna get a quote for replacement from indy shop. Used tissue on pcv on valve cover, it sucked in, stopped, sucked in, and stopped kept repeating which factored that out.
Instgram @burninja
