2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions DIY Front Bumper Plugs
      03-15-2018, 11:36 PM   #1
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
2013 BMW M5 [SOLD]  [10.00]
2013 BMW 535i [SOLD]  [10.00]
Hello!
I recently was given a front license plate tow hook from a friend that didn't want to use it so I figured perfect time to do a front plate "delete". I installed the tow hook plate and finally got it to work with the front motion sensors. Then came time to fill in the holes . For some wonderful reason, my car had 6 holes; 4 for the frame and 2 additional ones from the dealer using super long screws for the plate. I looked at options online and it was like ~$25.00 per two plugs. So I went ahead and made my own.
What you need
- Color matching paint (preferred from the dealer)
- # of retainer that you need to us (for me it was 6)
- A drill (I used a 1/4 inch drill bit but size may vary based on what size retainer purchased)
Process:
1) Purchase the correct retainer and the correct amount. I was able to get mine at McLandon Hardware store but most stores have them. They were super cheap so I recommend buying 2 or 3 extra just in case.
2) Painting the retainers. I used an old foam board to keep the retainers up while I painted them. I did the following method for painting:
- 3 base color coats (20 mins drying period between them)
- 3 clear coats (1 hr drying period between them)
- Let them sit overnight at-least before installing
3) Lastly, time to install the plugs. Clean the front bumper. Test to see if the retainer will fit in to the holes left by the plate/plate holder. Mine didn't so I had to make the hole a little bigger. I started with 1/8 bit and worked my way up to 1/4 inch. Please be cautions when doing so or else you can crack your clear coat/paint. I also had to cut the retainer from the back on two of them (top inside ones) so that the face would sit flush with the bumper.
Final result:
I hope this helps. Pretty easy modification. Feel free to leave feedback or ask questions I'll try to answer.
Thanks for reading,
      03-16-2018, 04:06 PM   #2
Drizel
Drizel's Avatar
17
Drives: 2017 X5
Originally Posted by Ickdeep View Post
Hello!
What you need
Process:
Final result (still missing one because it broke but I will update it after I complete the last plug & when I actually use my DSLR)
Thanks for reading,
Great write up!
On my things to do list, and this will help!
Thanks!
Ickdeep5706.00
      03-17-2018, 05:12 PM   #3
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
Updated photo:
      04-09-2018, 08:22 AM   #4
Mobh13
Drives: 2013 528i
2014 BMW 528I  [0.00]
cool mod I liked it
      08-04-2019, 01:11 AM   #5
Muslenutz
Muslenutz's Avatar
55
Drives: Bmw 540 2018
Updated photo:
How have they held up
      08-04-2019, 10:55 AM   #6
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
Updated photo:
They held up well. I sold the car like December 2018 and picked up a M5.
      08-04-2019, 03:13 PM   #7
Muslenutz
Muslenutz's Avatar
55
Updated photo:
I found some nice fasteners at Lowe's a little smaller actually. Do you think clearcoat white spray paint would hold up?
      08-04-2019, 06:25 PM   #8
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
Updated photo:
Yeah it should. Just be careful installing them into the bumper. If they flex just a little, it will mess it up. I made eight total when I made them and I think two broke during install
      08-04-2019, 10:47 PM   #9
Muslenutz
Muslenutz's Avatar
55
Updated photo:
[img]
View post on imgur.com
[/img]
I played with a few I bought today. Drilled and they were able to screw in snug. Was able to unscrew them out. I'm going to paint and call it a day with the spare paint. I'll prob get a ticket at some point and put on a plate. Bottom line, I have 6 holes from the dealer and I'd rather just plug them then spend 70-80 bugs for bumper plugs.
