09-30-2018, 02:42 PM | #1 |
Rep 36
Wheel spacers
I need some information I want to get some wheel spacers installed on my car., I have the regular stock m rims 19" on my 2013 bmw 550xi. I wanted to know what spacers should i get would
Like my rear to come out more for some grip |
09-30-2018, 09:51 PM | #2 |
Rep 2,194
15mm rear and 10mm front. I recommend the BMS Tuning brand spacers personally, but any quality spacers and extended bolts will be fine.
Bake
09-30-2018, 10:00 PM | #3 | |
Rep 36
10-01-2018, 08:09 AM | #4 |
Rep 2,194
Bake
10-29-2018, 09:27 PM | #7 |
Rep 2,194
373's have the same offsets as 351's. 10mm front and 15mm rear.
Bake
11-20-2018, 12:10 AM | #9 |
Rep 1
I have 12mm in front and 20mm in the rear. No issues on stock m sport 19".
https://drive.google.com/file/d/1-71...w?usp=drivesdk https://drive.google.com/file/d/1-4u...w?usp=drivesdk https://drive.google.com/file/d/1-8r...w?usp=drivesdk https://drive.google.com/file/d/1-9a...w?usp=drivesdk |
11-20-2018, 03:46 AM | #10 |
Rep 14,522
looks good and flush!
11-25-2018, 06:43 AM | #12 |
Rep 1
Seeing the recommendations I just wonder if the track width of a xDrive (AWD) model is different as I just changed from 18" to the 351m 19" on my 535i xDrive Touring and don't think I could fit any spacer up front without the wheel sticking out. On the rear I have added a 12mm which also seems the max. Maybe it is because the ride height of the xDrive which results in no negative camber (even slightly positive) at the front?
11-25-2018, 12:08 PM | #13 | |
Rep 29,202
12-22-2018, 07:21 PM | #15 |
Rep 116
Drives: 2021 G05, 2014 F10, 2009 E90
I'm running with 0mm front and 15mm rears for tiny bit more grip+looks. Depends how aggressive you want it to be.
12-23-2018, 11:48 AM | #16 |
Rep 23
03-08-2021, 09:31 PM | #17 |
Rep 24
So I know this is an old thread, but wanted to just see if I understand this correctly, on a stock 2015 550i xDrive with 19s square setup, a 15mm spacer for the back should be sufficient, correct?
08-02-2023, 12:32 PM | #18 |
Rep 398
Just listed a set of Turner Motorsports Spacers with extended lugs in the marketplace incase someone is looking. 12.5mm & 15mm. Barely used.
https://f10.5post.com/forums/showthread.php?t=2037908 |
