06-06-2022, 03:16 PM | #1 |
Rep 1,442
Drives: 2011 535i 6MT
My n55 Build
Hello-
I decided to start a build thread and I'll be doing YT videos on it, so I'll post new episodes here. I'd really appreciate the support on the channel so please go like and subscribe if you have a minute... Here are a list of current and planned upgrades. Let me know if you have any questions/comments or would like links to anything! Thanks, Engine: PS2 PWG TurboSmart BOV FTP Boost pipe Kit GPlus Intercooler Armytrix catless Downpipe Armytrix Valved Exhaust Custom Tuned by David Shoup on MHD BimECU MHD flex fuel canbus module Heat sunk and fanned EKP Walbaro 535 LPFP VVT front main seal guard VVT coolant flange BimmerHausPerformance behind the grill intake BimmerHausPerformance High Flow Inlet B58 Coils Snow stage 2.5 meth kit (100% meth) with SS lines and 7.5 gallon tank Sprint booster "pedal tune" Spool Helix Overdrive 3x King rod bearings 1 step colder plugs from n20 gapped to .028 550i Clutch and pressure plate M factory singlemass lightweight flywheel UUC short shift kit Poly bearings for shifte S55 oil pan with baffles S55 primary and secondary oil pump BMS oil cap BMS oil cooler plunger Suspension/brakes/bushings: BC Coil overs modified by red shift H&R front and rear sways Turner thrust arm mono ball bearings Shortened sway bar end links Polyethylene rear diff main bushing Polyethylene carrier bushing for shifting linkage Apex arc-8 19” by 275 square set up Exterior: CF rear spoiler CF roof spoiler CF radio antenna cover Hydro dipped m style mirror caps M Side skirts with extensions G80 M5 front bumper for F10 CF M5 front grills 3 piece Front lip M sport rear bumper Custom rear diffuser CF M quad tips Red Cross bars, engine supports Blacked out handles Shadow trim (DIY) Tint all the way around, including front windshield Blk/White CF roundels and wheel caps M style tire caps Custom front license plate w/ CF cover Interior: Full Black Interior swap Alcantera A, B, C pillars including rear deck Painted grey accents to black M sport shifter M style leather shifter boot LED ambient lighting upgrade to Red Rear view mirror upgrade Side mirrors are Euro spec with blind spot elimination Refitted worn out buttons Retrofit front comfort seats Retrofit Rear folding seats Retrofit rear heated seats Retrofit HUD M style door sills LCI steering wheel 6WB Cluster 11.2" Android touch screen Full Rockford Fosgate 8" 300w subs Bav Sound speaker replacement BimmerTech upgraded amp Rockford Fosgate 300w powered sub Retrofit Piano black trim package Red Seatbelts? Last edited by BimmerHausPerformance; 06-06-2022 at 03:30 PM.. |
06-06-2022, 05:47 PM | #2 |
Enthusiast
291
Rep 275
Drives: 2025 M4 Comp xDrive
Nice man! Excited to see you're build especially when the front bumper goes on
2025 M4 Competition xDrive
IG: Automaz_ |
08-08-2022, 08:45 AM | #3 |
Rep 1,442
Here is episode #2 - full leak down test! And yea, Houston, we have a problem...
01-17-2023, 11:08 AM | #4 |
Rep 1,442
I just posted Episode #4, full N55 tear down and plans for a 9k RPM big turbo build! I appreciate the support and please subscribe to the channel! Oh, and anyone posting that this build won't work... you are probably right but I'm still gonna try to make it happen. Gotta push the envelope.
