09-06-2023, 12:48 PM | #1 |
Rep 41
Drive shaft missing ??
So was doing a trans flush among other things and noticed...this is a 535 xdrive..should there be a drive shaft there ?? There is nothing going to the transfer case, looks as if there should be a drive sfhat the runs like parallel to the transmission no?
09-07-2023, 05:15 PM | #8 |
Rep 41
here you can see a little better, this is from drivers side looking up you can see transmission and where it looks like there should be a drivshaft, again this is 535xi 2011 what are your thoughts?
09-07-2023, 07:18 PM | #9 |
Rep 150
Looks like that drive shaft has been missing for a while (flange threaded hole have rust in them). Can you tell us more about the car (e.g, when purchased, any fault of on the dash, how long you been driving it like this, etc.). Sorry I cannot help you but am curious.
Regards, |
09-07-2023, 07:40 PM | #10 |
Rep 41
Haha absolutely, just purchased the car, I went against my better judgment and bout it with 130k carfax looked good maintenance records show ot had been serviced at bmw its whole life so I figured hey why not. Live the car but little things are starting to happen and it's only been 3 months, I saw in another thread here on the site that some people take front drives driveshaft off during summer and then back on during the winter, I am wondering if that was the case here, Car runs the same no lights on the dash or anything, I wonder if they took it off for fun or something was wrong with front diff.
StradaRedlands5953.50 |
09-08-2023, 06:28 PM | #11 |
Rep 246
F10s are designed to be primarily rwd and only transition to fwd when rear traction is inadequate. I suspect that running this car as fwd for God knows how long may have major consequences for the transfer case and other bits.
CrippledLucifer139.50 |
09-08-2023, 08:51 PM | #12 |
Rep 41
No no lol.its missing front drive dhaft so car is currently RWD only.
09-09-2023, 08:52 AM | #13 |
Rep 246
Suggests issue with transfer case by previous owner, so AWD was disabled.
09-09-2023, 09:05 PM | #14 |
Rep 3,581
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.25]
2009 BMW 328i Touri ... [8.00] 2013 BMW X5 35i [7.80] 2011 BMW 528i [8.70] 2006 Mazda3 [5.50] |
I wonder if it has X Delete flashed, otherwise wouldn't it throw codes?
https://www.xdelete.app/ |
09-09-2023, 09:08 PM | #15 |
Rep 1,508
Looks like AWD was disabled by previous owner. See if the front axles are still there. There is a chance previous owner disabled it with xDelete or code it to be RWD. That is why you won’t get any error messages on the dash. Hopefully they disabled it because they wanted to be RWD instead of disabling it due to a bad transfer case. Only one way to find out is to get a driveshaft and enable xDrive again.
ChiltiCoatl891935.50 |
09-09-2023, 10:29 PM | #16 |
Rep 5,611
It's probably the angle, but that 1st picture makes it look like if there was an axel attached to that fitting, it would hit that hose and piece of metal next to it.
09-10-2023, 05:18 PM | #19 |
Rep 3,581
Previously owner egregiously mis-represented the car as AWD. I wonder if you have any legal recourse. Selling a car as AWD and it missing a drive shaft is pretty underhanded.
09-10-2023, 08:03 PM | #20 |
Rep 41
Yea I was wondering the same thing 🤔 I love the car minus the few things that have gone wrong with it.
09-11-2023, 12:02 PM | #21 |
Rep 2,928
Who did you buy it from? And was it advertised as AWD or XDrive? Presumably yes. If a private seller, how long had they had it? If they had it several years, they had to know they were misrepresenting the car. A used car dealer may not have known, but still mispresented what the car was. You buy an older used car "as is" but that does not necessarily apply if the car is misrepresented. I'd confront them and see if you can at least get them to spring for a drive shaft.
09-11-2023, 12:09 PM | #22 |
Rep 2,928
Hold on a minute - in your very last pic where you show the side view and say "you can see a little better" - what am I seeing in the upper far right corner of that picture? Is it an optical illusion or is the aluminum case of your transfer case broken open and badly cracked?
