2010 2011 BMW 5 Series Forum F10 535i Custom Exhaust Cold Start (M5 Muffler, X-Pipe, J-Pipes) |
04-07-2017, 04:07 PM | #1 |
Rep 1,890
535i Custom Exhaust Cold Start + Revs (M5 Muffler, X Pipe, J Pipe, JB4+E85)
Hey all,
I posted this on reddit in /r/bmw and got a lot of good feedback so I figured I'd share with you guys as well. Here's a cold start and revving video of my 535i with M5 mufflers (valves closed), an x-pipe in place of resonator, and two 36" J-Pipes for drone reduction, not that there really is any but I commute regularly and wanted to make sure my highway cruising was dead quiet, which it is! |
04-07-2017, 06:53 PM | #2 |
Rep 4,209
Sounds awesome.
So what's the deal with the valves. I wanted to get some M5 mufflers but how does the valve system work? AKA open/close them? |
04-07-2017, 06:58 PM | #3 |
Rep 1,890
If you have a 550 then you can hookup the valves to your vacuum lines and they will open and close depending on throttle and RPMs for volume control. If you have a 535 we don't have vacuum lines for valves so you either keep the valves closed or keep them permanently open. I found they caused severe drone when permanently open, but when closed they still give the same beautiful sound but with minimal to no drone. Pretty remarkable how 2 more tips can cause so much volume.
04-07-2017, 07:32 PM | #4 |
Rep 2,825
nicely setup exhaust, well done.
the ecu does need to adjust to the new mods which takes about 300 miles. expect the exhaust to sound better once this is done. it is best to do each exhaust mod one by one for the sake of the ecu. by j pipe, did you mean downpipe? so there is no drone with an x-pipe right? |
04-07-2017, 07:35 PM | #5 | |
Rep 1,890
I did this about 2k miles ago and am currently running a JB4 on map 5 with about 35-40% E85 on this clip. No drone with the X pipe. It def brought the mufflers to life which can feel a bit quite at times. I have a catless DP I'll be installing soon as well. |
04-08-2017, 05:07 AM | #6 |
Rep 14,522
sounds pretty mean! for the 535 guys i'm wondering if you could hook up QTP's with the wireless remotes?
04-08-2017, 12:26 PM | #7 |
Rep 1,890
04-08-2017, 06:04 PM | #8 |
Dream crusher
984
Rep 2,421
Good stuff sounds good
IG: @bmwdoubles |
nwob15.50 |
04-10-2017, 03:56 AM | #11 |
Rep 14,522
i'm only slapping on the Meisterschaft mufflers as i don't have the complete catback. do those x-pipes back really make a difference?
04-10-2017, 09:27 AM | #12 |
Rep 1,890
04-10-2017, 02:56 PM | #13 |
Dream crusher
984
Rep 2,421
Nice looks great! Did you go through Juan?
IG: @bmwdoubles |
04-10-2017, 02:57 PM | #14 |
Rep 1,890
I did. Having some issues with rattling around the X pipe and a whistle on the right exhaust tips at WOT.
04-10-2017, 03:04 PM | #15 | |
Dream crusher
984
Rep 2,421
I saw this on the gram. Thought it was a cool concept to J Pipes.
IG: @bmwdoubles |
04-10-2017, 03:10 PM | #16 | |
Rep 1,890
Definitely a cool concept but seems pretty expensive to custom fab. I think that's the akrapovic exhaust if I'm not mistaken? |
04-10-2017, 05:21 PM | #17 | ||
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
04-10-2017, 05:22 PM | #18 |
Rep 1,890
I had that done as well, that's not where the rattle is coming from. It comes and goes so I'm not too concerned with it. When I go to put my catless DP on I'll see if they can identify the noise.
04-10-2017, 05:24 PM | #19 | |
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
04-10-2017, 05:44 PM | #20 |
Rep 1,890
04-10-2017, 07:16 PM | #21 |
Rep 5,362
04-10-2017, 07:29 PM | #22 |
Dream crusher
984
Rep 2,421
VRSF
IG: @bmwdoubles |
