2010 2011 BMW 5 Series Forum F10 Thinking about some upgrades - F10 LCI 535 xdrove |
12-31-2019, 02:56 PM | #23 |
Rep 1,299
You contradict your own comment. BMW also thought 300hp is reliable for n55 engine plus pushing extra power out of a small turbo isn't a good idea as you are crossing it's reliability, so pushing more power is also not a good idea than at all. Also, xHP tested on stock car showed better 0 to 60 times with their trans tune.
And better line pressure so clutch don't slip when you pushing more power saves the trans from damaging it vs pushing more power and let the clutches slip causing clutches to wear out quicker. Aplina does fast shifts on their cars on same trans that comes in regular cars... Which shows the trans is capable of fast shifts. Last edited by ziekxq; 12-31-2019 at 03:02 PM.. |
12-31-2019, 03:04 PM | #24 |
Rep 14,522
I've never heard of one single member who installed a catless dp or even a catted dp on their 535i ever say they didn't notice a difference.
12-31-2019, 05:36 PM | #25 | ||
Rep 4,632
I honestly didnt feel much of a difference in actual propulsion. The turbo spool and slight wastegate rattle, yes. Otherwise even my exhaust did not become much louder other than my coldstart. I think the same way guys are a lost for words and comment on how their world changed with a simple stage 1 tune, might be the same guys with 40whp DP gain lol All jokes aside, i think the size or better stated, flow of our turbos, PWG in my case, and the advance in modern cat technology, has become pretty good. We forget how well it can actual flow, and focus on the retailers constant use of 'restrictive' cats, to falsely lead us back into a state of 1985 cat tech. Happy new years guys!
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
lsturbointeg9155.50 |
01-05-2020, 01:25 PM | #26 | |
Rep 1,299
Did you read that article from xHP? Plus, if Catted downpipes flow better wouldn't exhaust sound louder just like Catless downpipe sound? I mean one of the reasons and correct me if I am wrong is the exhaust sound gets louder because there is no restriction in air flow from turbo down to exhaust because of no cat. Maybe the power you gain is not significant but the purpose might be to allow extra heat created by the turbo pushing more power to exit out quickly rather than stuck between turbo and cat possibly hurting the turbo in long run? Also, I remember from my JB4 days the reason they didn't recommend map 2 with Catted was because it was melting the cat inside the downpipe due to more heat. Last edited by ziekxq; 01-05-2020 at 07:36 PM.. |
01-06-2020, 06:47 AM | #27 | |
Rep 1,873
A year ago when I started considering some light flash tunes for ECU and TCU I was looking at issues such as the above. All of the tuners were rescaling the ECU-reported torque numbers to work around customers noticing the 3rd and 6th gear torque limits kicking in and reducing performance in those gears. So, for those of us who aren't drag racing from stoplight to stoplight all the time, we're in a situation where fixing a problem that occurs 0.1% of the time leads to systems operating incorrectly the other 99.9% of the time. At flash time, MHD asks you to pick transmission options. If you pick regular AT you get rescaling. If you pick MT / xHP you don't. xHP allows you to preserve the factory torque limits, or rewrite them on a per-gear basis. If I remember correctly, I believe that I left the factory torque limits in place. At the time, anyways, BM3 provided no specific information on what they did, and how they planned to continue in the future, so I think with BM3 you're stuck with rescaling no matter what. I'm only stage 1, and probably never going any further. It was a nice bump in power, and I'm not saying to myself that gears 3 and 6 are "so slow". I do not like to notion of ECUs "lying" to one another and chose my software (MHD + xHP) to allow that to be prevented. I know that BM3 now bundles some kind of transmission tune. They may have finally done this to work around this very issue. |
01-06-2020, 11:52 AM | #28 | |
Rep 2,590
https://www.facebook.com/protuningfr...2620716190170/ It seems like they aren't just simply rescaling the power output the ECU reads out. Seems like they actually raised the torque limits to 550. |
01-06-2020, 12:35 PM | #29 | |
Rep 1,299
01-06-2020, 04:09 PM | #31 | |
Rep 1,873
01-07-2020, 09:48 AM | #32 |
Rep 2,590
Yea, BM3 definitely doesn't do what xHP is doing. If you're looking to just resolve the torque issue, BM3 is fine. I don't care for shift point changing and all that, so xHP was pretty hard to justify.
