2010 2011 BMW 5 Series Forum F10 BMW 374mm x 36mm Euro “High Speed” Front Brake Upgrade for F10 |
09-08-2019, 11:42 PM | #25 |
Rep 342
10-23-2019, 04:50 PM | #31 |
Rep 342
Your question is a little ambiguous. Yes, it is going to require a larger wheel to fit (19") the larger rotors. The offset of the carrier/rotor appears to be the same so inner clearance should be the same.
02-11-2020, 10:08 PM | #38 |
Rep 342
02-12-2020, 09:20 AM | #39 | |
Rep 137
https://ceika-store.com/products/cbk...BoCze4QAvD_BwE |
02-12-2020, 09:24 AM | #40 |
Rep 134
this also direct bolts (With spare parts mentioned) to a 528i?
Been looking to upgrade my brakes..
2013 M Sport 528i - HM Style Carbon Fiber Front Lip | Dual Slat Gloss Grill w/ M colors |H&R Front / Rear Sways |Downpipe (Catless) | Afe Intake |
02-17-2020, 04:41 PM | #41 |
Rep 949
Yes they should bolt on directly to your 528i. Only think you want to make sure is you have 19" wheels or bigger since I don't think smaller wheels would fit over these. Maybe they will fit on 18 but im not sure..never tried.
02-22-2020, 02:29 PM | #42 |
Rep 489
I'll buy pm contact info. Does the 760 use bigger rear brake and is their any coding for the larger brakes. I think dsc should be fine cause I will reuse my caliper but my concern is letting the dme know the higher heat capacity for fade compensation
02-23-2020, 03:27 PM | #43 |
Rep 342
Hi Rob, i replied via text. I never researched the rears as i believe they do not have the e-parking brake or maybe they were the same... I have no idea regarding these issues regarding programming the DME. I would guess it doesnt matter as it would use the ABS sensor to see the wheel rotation. The master cylinder/brake booster should be same as the caliper piston size is the same. You are just getting more rotor to keep the temps down, more pad surface area and more brake force since the pads have a "longer lever" on the larger rotors.
