01-22-2020, 01:59 PM | #1 |
Rep 423
DME Update
Ok, I've been searching the forum for a little while and I can't find an answer or DIY for updating the DME. Is this something that can be done as a DIY or do you have to go to the Stealership.
Checkout my YouTube channel, Like and Subscribe. https://www.youtube.com/user/Gjohnson7771 MHD Flash, RVG Catless DP, RVG CP, RVG Boost Pipe, Walbro 455 LPFP, Style 433 Wheels, BC Coilovers, Ebay Strut bar, M-Sport Front Conversion, RVG FMIC, 6WB Cluster. |
01-31-2020, 11:27 PM | #2 |
Rep 423
Anyone???
02-01-2020, 08:14 AM | #3 |
Rep 915
Havent had experience with them yet, if you have instagram mybimmerbrain can remotely do this cheaper then dealer. Otherwise all a indy mechanic shop and ask if not stuck with dealer. Id be to afraid to brick any computer built in the car if I did myself. Best to keep it to experienced. I need mine checked/done as well.
Instgram @burninja
05-08-2020, 03:40 PM | #4 |
Rep 1,306
You can with ISTA-P I think you need the older version for pre LCI.
there was a tech on ebay who was selling the older version or pre LCI version. I think its was around 250 for the dealer to do it. I would go that route if that price is still that same. |
05-11-2020, 10:06 AM | #5 |
Rep 14,522
Why would you need to update the DME for?
05-11-2020, 01:42 PM | #6 |
Rep 423
Well I know I will need to update the kombi ECU if I upgrade the cluster and I was using Ista+ doing a diagnosis on a roughly idle. I tried to reset adaptations, however some crankwheel adaptation wouldn't reset because it said I needed to update one of the other ECU's. I thought it might make sense to update them all.
