01-04-2020, 11:09 AM | #1 |
Rep 85
Battery Charger
Any recommendations on battery chargers? I do not want to keep the car running while using Carly and making changes, so looking for something simple that I can use to keep power steady. Was considering this one...
Ampeak 2/8/15A 12V Smart Battery Charger/Maintainer Automatic with Winter Mode https://www.amazon.com/dp/B07DD8BJ9V..._0zmeEbGNXAY7Y Any thoughts? Thanks! |
01-04-2020, 10:37 PM | #4 |
Rep 4,632
I use the oem BMW charger which is made my C-TEK, great success in keeping the battery healthy, and during diagnostics via ISTA and such.
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
CommoN8149.00 |
01-06-2020, 07:00 AM | #7 |
Rep 1,873
I like my CTEK MXS 5.0 (which is apparently nearly identical to the older MUS 4.3 except that the MXS incorporates ambient temperature via a sensor into the charge plan) for routine overnight top ups and maintenance, but it's nowhere near enough power for coding/flashing and not really the question I see you asking.
With the ignition on and engine not running, I think N55 F10s draw around 50A, maybe more. Sure I'll connect my CTEK, plus another 15A bulk charger I have around, but even combined they aren't enough. You need something more like a 75A or 100A 12V "power supply" for serious coding or flashing. |
01-06-2020, 10:58 AM | #8 | |
Rep 5,362
01-06-2020, 03:23 PM | #9 | |
Rep 14,522
CTEK 40-206 MXS 5.0 12volt battery charger or Bmw Advanced Battery Charging System
01-06-2020, 10:15 PM | #10 |
Rep 305
Go with the ctek charger. It's slim and comes with a carry bag that can fit perfectly in the trunk compartment. I got the ctek mus4.3 about 4 years ago and still love it. It could check/test the battery, starter, and alternator.
lsturbointeg9158.50 |
01-06-2020, 10:40 PM | #11 |
Rep 5,362
Ditto, but for a different reason. The CTEK looks to be 5a while the BMW looks to be 1.25a; too weak IMHO.
01-06-2020, 11:29 PM | #12 |
Rep 14,522
Just ordered from Amazon Prime. Thanks guys
01-07-2020, 09:55 AM | #13 |
Rep 2,590
While coding, a charger or even just pure battery power will be fine most of the time. It's programming where you need to start looking at power supplies.
01-08-2020, 10:50 PM | #14 |
Rep 14,522
what the difference between using the alligator clamps and the what looks like o-ring connections?
01-08-2020, 11:06 PM | #15 |
Rep 5,362
How often you'll be using the charger and ease of connecting and disconnecting. I installed the o-ring connectors to the under-hood terminals. Hook-up is easy peazy, lemon squeezey. I also bought an extension cable so I can centrally locate the charger for use on both cars.
01-08-2020, 11:08 PM | #16 | |
Rep 14,522
01-08-2020, 11:53 PM | #17 | |
Rep 5,362
01-09-2020, 09:50 AM | #18 | |
Rep 2,590
01-09-2020, 04:53 PM | #19 | |
Rep 5,362
01-09-2020, 08:29 PM | #20 |
Rep 14,522
So in showing the battery is fully charged as the last light is on. Do I just leave it on and the charger will take care if itself or do I need to disconnect it?
01-09-2020, 10:31 PM | #21 |
Rep 5,362
You should be able to leave the charger hooked-up and the charger will float the charge. As the battery drains the charger will keep it topped off.
01-09-2020, 10:43 PM | #22 |
Rep 14,522
thanks my man! this is the first year I've actually done this as it was a PITA last few year driving it around to keep the car from dying during the winters
