2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum What power steering do I have?
      01-11-2020, 09:45 PM   #1
walmark
Apprentice
walmark's Avatar
86
Drives: 550i F10 '15
I'm sure it's obvious to some of the knowledgeable people around here, but I am a little confused based on what I see under the hood.
From my reading I found that the Xdrive models have a hydraulic power steering while the rear drive models have electric. That's why you can have parking assistent on the rear wheel drive but not the xdrive.
I have a 2015 550i rear wheel drive with integral active steering and parking assistent. But when I open the hood I can see a power steering fluid reservoir in front of the engine bay on the driver side. So... electric or hydraulic?
      01-12-2020, 04:58 PM   #2
HighlandPete
Drives: BMW F11 535i Touring
Have you got Adaptive Drive? (DHP). ARS (active roll stabilisation) uses a hydraulic pump, so has the appearance of HPAS being fitted.
I've got EPS and the hydraulic components for ARS, on my 535i.
      01-12-2020, 05:37 PM   #3
walmark
Apprentice
walmark's Avatar
86
Ok, that makes sense. I do have adaptive drive with ARS. I just didn't know that it uses power steering fluid and reservoir for hydraulics.
Do you know if it also has a belt driven power steering pump to pressurize the fluid? Or is it electric?
      01-13-2020, 03:32 AM   #4
HighlandPete
Yes, belt driven and runs at pressure, which is reduced off load. The xDrive models with HPAS, uses the same pump and ancillaries for the steering and ARS.
      01-25-2020, 05:27 AM   #5
thakid22
Drives: 2021 Bmw M340i M-Sport w/ VDC
On a side note...
Are you guys with ARS seeing lots of body roll?
15 535i Msport with DHP/ARS had hideous amounts of body roll.
More than any car I have recently driven. It almost seemed that ARS wasn't even present.
Very very soft roll control. Especially in comfort mode. Things were a bit more flat in Sport mode. But still nothing like the table flat ARS in my old 2010 535i Msport with ARS.
      01-25-2020, 11:12 AM   #6
walmark
Apprentice
walmark's Avatar
86
On a side note...
It's hard for me to say. There is definitely some body roll, but I guess it's less than what I would expect from this size car. Then again I have not driven 550 (heavy!) without it so it's hard to compare.
