2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes F10 to-G30 OE wheel swap project complete. How does it look
      08-22-2019, 05:36 PM   #1
Sailor535
Drives: 535i
I swapped my F10 wheels out for the 2017G30 OE Wheels. Adjusting the hub size & bolt pattern via custom spacer/adapter from a machine shop. Since I was going for just an updated OE look & not a wider stance, I am not 100% sold just yet. How do they look??
Bolt Pattern
Wheel facing = G30 (5 x 112mm)
Car/hub facing = F10 (5 x 120mm)
Bore size
wheel facing bore size lip/flange reduced to fit the 66.6mm to maintain a hubcentric fit
19x9 ET44 w 17mm spacers
No signs of rubbing, but I've only driven a "tame" 10-15 miles...
cdmulders326.50
EV8634.00
      08-22-2019, 09:34 PM   #2
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Sweet!
      08-22-2019, 09:39 PM   #3
Oreen0
Drives: E90
Looks Great!
      08-23-2019, 10:30 AM   #4
cdmulders
cdmulders's Avatar
Drives: 2013 535xi
Looks good. Did you have to use custom nuts to secure the wheels? From the pics, I can't see how you could use the stock bolts. Also, looking at the side profile, you might be OK if you want to lower your ride. Congrats on being the first person I've seen to use these F10 / G30 wheel adapters.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension
2000 528i, Cosmo Black, beige interior, Sport package (retired)
      08-23-2019, 11:18 AM   #5
Sailor535
Drives: 535i
Yea, No stock bolts. the adapter changed the config to requiring a nut. They sent me lug nuts for the adapter but since this machine shop focuses primarily on truck & tractor adapters they are way to f'ing long. I have some on order from ECS & Amazon, will keep the ones I like the best...
      08-23-2019, 06:04 PM   #6
cdmulders
cdmulders's Avatar
Drives: 2013 535xi
Originally Posted by Sailor535 View Post
They sent me lug nuts for the adapter but ... they are way to f'ing long.
I wasn't going to say, but I agree that they do seem to stick out a bit. Since they are black, they don't really show up that much. I'm still impressed that you found a solution to retrofit wheels from a newer model BMW onto our F10s.
Cheers!
      08-25-2019, 02:12 PM   #7
Casebrius
Drives: 2016 535 M-Sport; 95,97 E36 M3
I like the 351's better...
      06-26-2023, 08:12 PM   #8
zakabu
Drives: BMW 520d 2014
Compatible spacer
Hello, I'm searching for a compatible spacer for my 5 series vehicle for the same setup. Do you think this particular spacer, found at this link on Amazon UK, would be a suitable option? Here's the link: https://www.amazon.co.uk/Precision-A...dp/B0BH5795LJ/
