05-15-2022, 12:23 PM | #1 |
Rep 207
F10 Diesel Maintenance?
Hi there!
Recently got into a 535dx - this is my first diesel since the diesel gate VW Jetta. I plan on keeping this car for life - was wondering what maintenance I should do? I would normally do plugs and coils at 85k - however I don't know a thing about glow plugs. Should I replace these ever? I just replaced my fuel filter - how often should that be changed on a diesel? I'm going to assume the OFHG , valve cover gasket, and oil pan gaskets will end up leaking like my n55 f15 and previous e60. Is that true? Do the fuel injectors on a diesel clog up? I have been using liqui Moly diesel additive. Thanks for any input - I'm a DIY kind of guy when it makes since with my busy schedule. Looking forward to diving in to the diesel engine! |
05-15-2022, 12:41 PM | #2 |
Rep 21
My 2014 535d is at 253,000 miles. Only had to do fluid changes to this point and filters. Did have to replace turbo at 220,000. I run hot shot secret or lucus in fuel regularly. Only unexpected repair was for plastic water neck on drivers side of engine, it split.
05-21-2022, 01:50 PM | #3 | ||||||
Rep 866
The Exhaust Gas Recirculation (EGR) cooler is on official recall on many of these cars with no known solution yet. Some High Pressure Fuel Pumps (HPFP) are on recall depending on the VIN number of the car as they can implode and ruin the entire fuel system with metal pieces so I would check on that too, but this happens rarely. Enjoy browsing! Last edited by Pierre Louis; 05-21-2022 at 02:09 PM.. |
05-22-2022, 06:07 PM | #4 |
Rep 44
Pierre is very knowledgeable regarding diesels.
My modest amount of knowledge is that unless you have an overhead lift, pay a professional to change your transmission, differential, and maybe transfer case fluids. I did the hard way, and without the overhead ease of position, you might kill yourself, heh. The plastic/fiber and its nuts will drive you insane. So far, I've had a Passat TDI, 335D, and still have a 2014 535D Xdrive. I did the full delete in the 335, and it was a monster of a machine, only Stage 2, but EGR, cooler, DEF, Cat, and everything downstream was gone. That was nice. I got older and went to the 535. Then I got the DEF tank fill level code, which gives you 1000 miles of driving. It was already full. Entire tank must be replaced, dealer quote $2500. I chose Stage 1 tune, included ignoring DEF and SCR function, no problems now for 20,000 miles and counting. Maybe you should register it in Idaho? To my knowledge, the 535D motor is not as susceptible to carbon buildup as the 335. So there's that. They aren't making these anymore, so why not go all out? |
Pierre Louis157.50 StradaRedlands4939.00 |
