06-13-2022, 01:06 PM | #1 |
Rep 3,030
Dumb exhaust question
So I have an opportunity to buy a used cross pipes, tried and tested on the 997 with great success. Retail is about $1400CAD new. I can pick one up used for $400 but there is a good sized dent in one of the pipes, image is below.
Should I consider this or just walk away? I have no idea if this affects performance or sound in any way? Gut reaction is to walk away, repair will likely cost enough that i may as well just go new. |
06-13-2022, 01:17 PM | #2 |
Rep 3,255
Yeah I think I would walk. That’s a fairly significant dent which appears to reduce the interior volume by roughly 30-40% in that section. I have to imagine there is some performance loss there as it’s now a bottleneck to some degree.
Pauldunlop13425.00 Dino GT35131.50 |
06-13-2022, 02:04 PM | #3 |
Rep 1,790
Not sure about context for this but sometimes pipes can come dented intentionally to clear bracing or other parts. Is that the case here? if not, yeah, skip it.
06-13-2022, 02:33 PM | #4 |
Rep 2,702
Drives: Built not Bought 04 Z4 VF
My.02 is that the piece that is damaged looks like a fairly straight piece. A simple fix and should not be too pricey a repair at a welding shop. Assuming it is run of the mill stainless steel.
W2A Intercooled Vortech V3Si, custom ducting, Alpha N, 60# Bosch,2.62 pulley, multi port WMI, Severn Tuning(pokeybritches), Tial, magnaflow,SS race muffler, 42 design,3.91LSD, H&R, Hotchkis,ST coils,Konis, Megan camber arms, AKG SS, Nylon mounts, Poly bushings, Carbon interior, CF Aero.APEX
grannyknot950.50 Dino GT35131.50 |
06-13-2022, 03:54 PM | #5 | |
Rep 779
Who is going to see it? Don't pass up a good deal like that. If you are willing to drive up to my place I'll do it for free.
2008 E86 M coupe
Dino GT35131.50 |
06-13-2022, 04:02 PM | #6 |
Rep 3,929
Most decent exhaust shops can pressurize the pipe, heat it up and form it back into shape. To be honest, I doubt you would notice a difference installing it with the dent.
Current: 2024 BMW M3 Competition xDrive | 2022 Audi Q7
Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5 |
06-13-2022, 04:55 PM | #8 |
Rep 3,929
It's surface rust lol you live in Florida...this is normal up here.
06-13-2022, 05:17 PM | #9 |
Rep 221
Engine Masters did a fantastic video on this exact thing. They progressively dented some headers more and more to see if it effected power output. In short, no, it didn't really matter. I say save the $1,000 and pick them up!
Video can be found here: https://www.dailymotion.com/video/x3vupq0 |
06-13-2022, 05:27 PM | #10 |
Rep 4,607
06-13-2022, 05:32 PM | #11 |
Rep 3,929
I certainly have...every year for the past 30 years! Road salt still does more on parts than humidity (even mixed with salty ocean air).
grannyknot950.50 |
06-13-2022, 06:17 PM | #13 |
Rep 787
That would take ~$250-350 to fix correctly, assuming you have a shop that is qualified and wants that kind of work. Correctly means cutting it out and replacing with a fresh patch which requires a donor piece of mandrel bent material of the correct size and grade, and using a TIG process with 309 or 312 rod. Probably a 2 hour job and $50 in material. I wouldn't use any other method. I manufacture stainless turbo manifolds and stainless exhaust systems, and that repair is not difficult, but would give me pause if I didn't have a solution lined up.
The material looks like aged 409 stainless, which is a lower grade, does a magnet stick to it? Given it's location in the exhaust stream that flow disruption isn't going to cause major harmonic imbalances, but it's still big enough have some impact, and is enough to bother me so I'd fix it if it were mine. |
Dino GT35131.50 |
06-13-2022, 06:57 PM | #14 |
Rep 4,155
Tbh that 'dent' looks like it may have been intentional, maybe to clear something. I don't see any strike marks/scratches to indicate it hit something. And the dent shape is just too perfect for it to have been made by accident.
06-13-2022, 08:14 PM | #16 |
/M Enthusiast
1597
Rep 1,617
I watched an episode of Motor Trend Engine Masters where they had to severely smash (close off) a header tube to see a change with the motor on a dyno. Offer $200 or walk.
https://www.motortrend.com/news/engi...-dont-have-to/
2019 M2 Comp, Alpine White, DCT, track car build, 1/2 cage, AP Racing Brakes & Nitron Coilovers, BM3 Stage 1 93 Oct.
2018 Porsche Cayman GTS, Night Blue Metalic, PDK, COBB tuned 93 Oct. 2004 Audi A4 Avant USP 6mt, RS4 clutch, built motor, Garrett GT3071r "Big Ass Turbo" Motoza Tune |
