2010 2011 BMW 5 Series Forum F10 Apple CarPlay Install options |
10-30-2020, 08:33 AM | #1 |
Rep 10
What is everyone doing in getting Apple CarPlay to play nice with iDrive??
Found this on a quick search / is there a more popular option? HifiMax site BMW Original Car Carplay Upgrade This Apple Carplay (Android Auto) interface is specially designed for BMW original screen, after installing this module, you will have apple Carplay & Android Auto and mirror link functions. Wireless Apple Carplay Android auto for BMW 1~7 series X1 X2 X3 X4 X5 X6 CIC NBT EVO |
11-10-2020, 03:20 PM | #2 |
Rep 688
I'm using an Andream NBT box for my 2014 F10. TONS more info at the following thread:
https://f30.bimmerpost.com/forums/sh....php?t=1675929
Retired- 2013 MG 328i Sport Line 6MT - BMS Stage 1 / M Performance exhaust / M Performance steering wheel / M Performance shift knob/boot |
texascfo5.00 |
11-10-2020, 04:07 PM | #3 |
Rep 27
I am using the Andream as well. In general day to day works well. On occasion losses Bluetooth connection for wireless airplay. But setting up again is no issue for me.
My best addition to the car by far. Use it all the time. |
11-10-2020, 05:33 PM | #4 |
Rep 688
Honestly, one of the main reasons I'm planning to keep my car for a lot longer. My wife's volvo has carplay and I legit wanted a car that has it.
Retired- 2013 MG 328i Sport Line 6MT - BMS Stage 1 / M Performance exhaust / M Performance steering wheel / M Performance shift knob/boot Last edited by ThaiBruin; 11-10-2020 at 08:51 PM.. |
12-07-2020, 09:26 AM | #6 |
Rep 32
Andream Carplay MMI and OEM camera
I have a 2014 535I XDrive and this past weekend, installed the Andream Carplay MMi. It was not difficult and hardest was removing the two green sound connectors and installing in the new system without breaking the clip. I also successfully hid the unit and carplay working great. Love siri use and waze and my music.
I have a problem though. I have OEM camera with PDC and while in carplay and I go into reverse, the Camera does not show but I can hear the beeping. If I hit menu and go back to Idrive, the camera works perfectly. I believe that the Rear view camera should automatically pop up whenever the reverse gear is engaged. It overrides everything and Carplay mmi or regular iDrive. Does anyone have any thought on this and maybe there is an issue with the Carplay settings or the unit? |
12-07-2020, 10:59 AM | #7 | |
Rep 688
I had mine professionally installed, and I know I saw the guy going into the settings and adjusted some of the camera options. I'm not sure which ones they were as I was just happy to see that everything worked as it should when he was done. The OEM camera should definitely still work if you're in the MMI and go into reverse.
12-08-2020, 04:55 PM | #8 |
Rep 32
Andream Carplay MMI
I was able to resolve the issue with OEM camera and now works - Reverse Line Detect must be turned off in the software settings for OEM camera.
I have another question though. Finally, before I installed carplay, I could make calls using my steering wheel button that was paired with my phone. Per carplay instructions, after I installed car play, I wiped the idrive pairing of my phone and BT. I then set up the phone as carplay BT. Now, in car play, when I select the phone button on the steering wheel, it says no BT phone connected and to connect. I would like to use the steering wheel phone button for carplay and does anyone have any thoughts? If I set up BT phone in Idrive again, would there be a conflict on which phone to use when starting car – Idrive or Car play? |
12-08-2020, 05:50 PM | #9 | |
Rep 688
https://f30.bimmerpost.com/forums/sh....php?t=1675929 Fairly certain you'll find a fix in there.
01-09-2021, 09:34 PM | #11 | |
The Hibernator
61
Rep 83
If you wanted to use both the steering wheel controls and carplay, you'd have to BT your phone for audio calling and USB plug your phone for carplay. I highly recommend just using Carplay as the call audio quality is FAR better than the car's bluetooth microphone. |
05-11-2021, 02:37 PM | #13 | |
Rep 60
08-15-2021, 12:36 AM | #15 |
Rep 329
Drives: F10 535i xDrive, F25 xDrive35i
I installed CarPlay into my F10 and it works fine... when it stays on. It'll randomly switch back the factory iDrive without notice. Help please!
11-03-2022, 02:50 PM | #16 |
Rep 172
11-27-2022, 05:52 PM | #17 |
Rep 7
I purchased the Mr12Volt Carplay interface:
https://www.mr12volt.com/collections...-interface-dsp (mine is the previous model) The main selling point is it uses the MOST interface for audio so you dont lose any quality by going via AUX. unfortunately it did not work. It doesn't recognise the iDrive controller, so while it is plugged in you cant navigate anything. I dont know if that's because my car is an AU model or if it just doesn't like the F10 in general. The support was very helpful but ultimately, even with another unit, we couldn't get it working. Just FYI in case anyone either has one (i would be interested in your experience, if it worked for you) or is considering one. I'm a little worried that if I purchased one of these other carplay interfaces, i would have similar issues. Has anyone in Australia with an MY12 had success with a carplay interface? |
01-20-2023, 07:40 PM | #19 |
Rep 6
I have been using carplay for 2 years. I’ve bought one from aliexpress( they are all the same) and fitted it to CIC system. Normally you can’t skip tracks from your steering wheel because you have to put it to Aux on your i drive. But Use the bluetooth audio from the original cic system or use usb in the glovebox, and now you have perfect quality music and steering wheel full controls.
01-20-2023, 07:42 PM | #20 | |
Rep 6
03-12-2023, 05:26 AM | #21 |
Rep 5
Hi
I have recently bought a 2016 BMW 518D SE, it has the small screen and I am thinking about a buying a new screen from Ali baba or Ali express, but theres so many to choose from. My budget is around £250. thanks |
03-18-2023, 01:50 PM | #22 |
Rep 11
Hi, anyone can tell me what's different between those two
https://www.aliexpress.com/item/1005...yAdapt=glo2pol https://hifimaxnavi.com/products/bmw...39470505656414 They are looks the same, its worth buying one of these? Anyone have experience buying from aliexpress? Last edited by iSlav; 03-18-2023 at 01:57 PM.. |
