2010 2011 BMW 5 Series Forum F10 Question: Importance of same diameter on front and rear wheels with X drive? |
01-25-2021, 11:16 AM | #1 |
Rep 154
Just curious. I see posts where folks are using different size tires on front and rear, and that might be Ok, but is it not required to have same overall diameter on all tires on a car with X drive? E.g. 245 x 40 x 19" tires will have 678 mm diameter, 26.7". It's OK to use a slightly different size, but shouldn't all four have same diameter (as each other). Thanks.
01-25-2021, 03:49 PM | #2 | |
Rep 1,907
It's worth also noting that in cases where staggered configurations are available from the factory, I bet you'll find that those tires are available in those sizes with "star designations" indicating "BMW OEM". BMW likely ensured that those sizes with the stars end up with very close rolling circumference when used in staggered configuration with X-Drive. If you don't get the star version this may not be the case. |
01-26-2021, 04:11 AM | #3 | |
Rep 15,857
My son ran a couple of E83 with staggered setups. When he needed new rear tires, for his 19" wheels, local supplier (a national outlet) didn't have approved tires. The manager wouldn't fit an alternative he had in stock, as he'd experienced too many issues doing so. He couldn't source any approved tires, (was a shortage nationwide at the time), but was willing to fit, if my son could source any. Long story short, not all tires are equal in dimensions. 'Star' marked approved tires can have different tolerances. Same with Mercedes and MO approved tires. |
01-26-2021, 08:50 AM | #4 | |
Rep 1,907
So for example the F10 535 with a staggered set up uses 245/40-19 and 275/35-19. I bet if you look through tire catalogs you'll happen to notice that BMW has star-approved tires in those sizes and will have ensured that the two are within acceptable transfer case limits. You might find that those two sizes (even same make/model) might NOT be close enough in rolling circumference for a BMW transfer case if they are not star-marked. All of the dimensions provided in tire sizing are approximations and ranges, just like with TVs, shoes, pants, grades of motor oil etc... A 1992 Porsche I had a long time ago came staggered from the factory. Porsche also has an "N" marking for approved tires. Of course most of us owners thought that was a scam to earn profit or drive tire sales through dealers. We also thought that fitting a wider profile would be "better". Long story short, instead of 205F and 225R I fitted 225F and 245R Bridgestone S-02 Pole Positions when I needed tires. The size specification was bang on according to tire calculators, and some folks noticed nothing odd, but it turns out that Bridgestone made the 245 tire on the "short and narrow" end of the tolerances and the 225 tire on the "wide and tall" end of the tolerances and it looked stupid instead of looking balanced. No transfer case to worry about at least in that case. Last edited by Surly73; 01-26-2021 at 08:55 AM.. |
01-26-2021, 01:41 PM | #5 |
Rep 154
Star marking?
So where does this star marking appear? (Interesting)
Is it actually on the tires themselves? The two sizes Surly quoted above are theoretically 0.5% different in diameter (and circumference, amazingly), but I imagine a worn tire versus a brand new tire is at least that much different. |
01-26-2021, 01:41 PM | #6 | |
Rep 15,857
The tolerance within DIN standard for RC is; +1.5% -2.5%. Apply that to tires BMW are using for staggered xDrive combinations, we can see BMW may well have much tighter (or different) tolerances for approved tires. Last edited by HighlandPete; 01-26-2021 at 01:56 PM.. |
01-26-2021, 01:55 PM | #7 | |
Rep 15,857
Regarding wear, BMW have indicated that a maximum 2mm of tread difference between wheels is the figure we should work within. Something like this; "The tire tread difference between tires in all wheel positions must not exceed 2mm". |
01-26-2021, 02:12 PM | #8 |
Rep 1,939
When custom sizing tires I typically will not go above 1% circumference difference from the factory tire size.
I use this calculator: https://tiresize.com/converter/ |
01-27-2021, 05:55 AM | #9 | |
Rep 1,907
01-27-2021, 05:59 AM | #10 | |
Rep 1,907
They've said a difference of 2mm RADIUS is their limit, equal to 4mm of diameter. Tiresizecalculator reports the nominal diameter of 245/40R19 is 678 for a cirumference of 2131. A reduction in 4mm of diameter would reduce circumference by ~12mm or 12/2131=0.6% |
01-27-2021, 06:12 AM | #11 | |
Rep 15,857
"The tire circumference can fluctuate up to 1% as a result of mixed tires or wear". |
01-27-2021, 08:35 AM | #12 |
Rep 154
That was smart of you to pick up on radius versus diameter. And as I'm sure you already know, it doesn't matter whether you're talking about diameter or circumference since the two are directly proportional. A 1% increase in diameter will be a 1% increase in circumference also. (Thanks for answering my original question. You confirmed that my expectation was correct; that all four tires (or tyres, for Pete) should be "the same" in diameter plus or minus a small tolerance. On an X drive.
01-30-2021, 12:08 PM | #14 |
cals
17
Rep 39
yes, you can run staggered wheels in an X-Drive, providing the diameter difference between Front and Rear wheels stays below +/- 1%
The BMW Manual lists several sizes (on this case for a 535ix); I have a set in the 19" size. |
01-30-2021, 05:06 PM | #15 |
Rep 406
Drives: 16 X3 28d/18 540d xdrive
On a 5 series xdrive sedan what are the advantages of staggered wheels/tires aside from appearance? It's understandable on a rwd sports cars, but I don't see where this would aid in the handling of a awd sedan.
01-31-2021, 10:08 AM | #16 |
Rep 154
Hoa, you have tires where all four are almost exactly the same diameter overall. You have different widths and aspect ratios, but they are all the same diameter, within the allowable tolerances. The original question, which was answered, was about diameter and therefore also circumference. In an x drive you want all four wheels turning at the same rpm or you might mess up the transfer case.
01-31-2021, 04:41 PM | #17 | |
Rep 2,637
245/35/20 F and 285/30/20 R is a lot safer at -0.4%
2015 BMW 535xi
02-01-2021, 01:13 AM | #19 |
Rep 2,637
Likely a mess up on BMW's part, there's occasional mistakes in their manuals. Always double check!
2015 BMW 535xi
02-01-2021, 03:23 PM | #20 |
Rep 15,857
The 275/30 R20 is the correct rear size for a BMW staggered setup on F10 & G30 models. Remember we are talking approved tires, not necessarily generic nominal tolerances.
02-01-2021, 04:08 PM | #21 |
Rep 2,637
Sure, if you only ever buy star tires. But for people who don't and don't know where to check besides the manual, that 275 is highly misleading.
2015 BMW 535xi
