2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Wont shift out of park.
      08-21-2019, 06:37 PM   #1
Hammazs
Drives: 2011 BMW 550i rwd
Just had a used transmission put into my car. I have a 2011 BMW 550i rwd. The repair shop said they cleared codes, reset adaptations, and reconfigured the transmission. It wont shift out of park. He tested the voltage and says I need a new alternator because its cranking out 15.5 volts witch is high. Because of this, it turns off the modules so they dont fry. Anyone have a similar issue with your car and if so how did you repair it?
      08-22-2019, 02:40 PM   #2
wcr3d
Drives: 2013 535i XDrive M Sport
That is assuming what they are telling you is true.
To me it stands to reason that it was working fine before the swap.
      08-22-2019, 04:02 PM   #3
Oreen0
Drives: E90
+1
      08-26-2019, 08:12 PM   #4
Hammazs
Turns out it was the alternator, not the transmission. I thought it was the transmission because it wouldn't shift out of third. The alternator was pumping out too much voltage witch put the transmission in limp mode.
      08-26-2019, 09:00 PM   #5
wcr3d
Glad you got it fixed and thanks for reporting back.
      08-27-2019, 10:06 PM   #6
Boosted M5
Drives: F10 m5
Thanks for the helpful insight! Sorry it cost you an alternator though.
