09-05-2016, 06:12 PM | #1 |
Rep 104
Mods to run map 7??
I've looked and looked and haven't seen but one f10 535i running map7. My question is what other mods do i need to be able to run enough e85 and get to 100 octane for map 7. As far as I know there aren't any fuel pump upgrades for the f10 (I may be wrong). Im currently running map 2 with 4 gallons of e85 and logs like fine. Have tried map 5 also but I prefer map 2. I would love to try map 7. Any input or help would be awesome. Thanks
2013 535i m sport Current mods: Jb4 map 2 with ff connector Bms intake Chargepipe Vsrf downpipe Running 4gallons e85/93 currently |
09-06-2016, 08:30 AM | #2 |
Rep 14,521
maybe Bmw doubles will chime in here a bit since he's the only one i know who's got the most upgrades done performance wise on the 535
09-07-2016, 02:58 PM | #3 | |
Joint Chiefs of Staff
24199
Rep 190,807
Missing an intercooler
10-04-2016, 11:22 AM | #4 |
IG @bmwF9xG80
3813
Rep 7,593
lnjwtr without seeing your logs you wouldn't know honestly, so check your FP_H value, timings and trims as you add E85. Also n54tech.com can help you more if you post your logs since thats the jb4 forum.
The PWG 535 seem e85 friendly i've seen cars running e40-e45 on stock fuel system Even 7 gals http://f10.5post.com/forums/showthread.php?t=1280179
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
10-04-2016, 12:16 PM | #5 |
Rep 104
Ok Thanks, ive posted a log with a couple gallons of e85 a while back and all was good. Since then gone up to 4 gallons and monitored logs myself. Looked fine. When i posted this i was really just looking for a ballpartk number of how far we could go. also talked to fuel it and they do offer a low pressure fuel pump upgrade for the f10. I plan on going that route soon and eventually getting pi or tbi not sure which yet.
10-04-2016, 12:17 PM | #6 | |
IG @bmwF9xG80
3813
Rep 7,593
4 gals + rest 93 is still very well under the limit, i use this as well http://www.georgebelton.com/E85Calculator.php
10-04-2016, 01:09 PM | #8 |
Rep 1,214
I'm running 5gal of E85 + 12gal 93 in my tank right now, no problems. Net E32. Everything is happy. Cold start with the E85 is kinda lumpy, but that goes away after a minute or so.
10-04-2016, 04:02 PM | #9 |
IG @bmwF9xG80
3813
Rep 7,593
Start low 3-4 gals and rest 93, then go through the whole tank before adding e85 again so you can have a good calculation on your next refill.
Every car is a little different but typically 535 handles e40 without a problem (7 - 7.75 gal of e85 + rest 93). Also is smart to invest in the fuel-it e85 tester
10-04-2016, 04:56 PM | #11 | |
IG @bmwF9xG80
3813
Rep 7,593
But hey start adding 1 extra gallon and make sure you log WOT to see how your parameters are running
10-04-2016, 09:04 PM | #13 | |
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
