2010 2011 BMW 5 Series Forum F10 transfer case replacement |
06-08-2018, 03:48 PM | #1 |
Rep 218
Well, I get to replace my transfer case on my '12 550i Xdrive. The issue started as a 0% throttle whine. Ultimately progressed to fairly significant drive train bucking mostly at 0% throttle but also during spirited acceleration. So, wanting to do this myself, but information on line is scarce. And, it seems that both the ACT 350 and 35L are listed as a fit for my model/year. The ACT 35L seems both more plentiful and cheaper.
My question is whether or not the ACT 35L is the updated and proper transfer case model? Anyone ever replaced the transfer case on an F10? BTW, I disconnected (power/controls) the transfer case control module and the noise and bucking are gone...except for very spirited acceleration. Of course I get a slew of warning lights: ABS, 4x4, parking brake, and adaptive cruise does not work...all to be expected. |
06-12-2018, 10:36 AM | #2 |
Rep 218
Update: Dealer says part number should be 27.10.7.649.725. ACT 35L. My cost is $602.58 + $1083 refundable core charge.
Guess I will go ahead and get it changed out...not looking forward to the task. Any other parts I will need? Last edited by David3; 06-13-2018 at 02:13 PM.. |
07-09-2019, 03:00 PM | #3 |
Rep 218
Second update: Part cost is way higher now. My new cost is $1920 + core. So, I decided to rebuild the unit myself. I opened it up over the weekend and it looked very good inside. The bearings seemed very smooth without any noticeable excess movement. The output flange splines seem worn and thus loose. I plan to use loctite 660 on the flange splines upon reassembly. I have ordered a clutch pack kit for $311 (including expedited shipping) and will install upon arrival (Wednesday). The existing clutch disks and steels looked okay, but I don't know how much material the discs had when new. The steels looked a little discolored, but not blued. And, I ordered a rubber guibo to replace the original aluminum version that I suspect contributes to the spline wear. BMW TIS demands that the rubber guibo be used upon reassembly.
I will update again after the unit back together and in the car. |
07-17-2021, 07:49 AM | #4 | |
Rep 606
Drives: 2000 M5, 2001 M5, 2013 M5 6MT
Two further questions - 1) is there any reprogramming needed when swapping units/replacing clutch packs? 2)were you able to remove the transfer case without dropping the whole trans? I assume the exhaust needs to come out, disconnect the driveshafts, crossmember(s), lower back end of the assembly. Just wondering if there's room to reach all the connecting bolts. |
10-16-2021, 10:10 AM | #9 |
Rep 455
There are several of us that have changed out our fluids. I would not hesitate to do it again. My car is at almost 140k, and without problems, knock on wood!
02-17-2022, 07:59 PM | #12 |
Rep 218
Sorry I disappeared…focused on other things. I never fixed the transfer case. New fluid and discs made it better for a short time only. I ended up electronically disconnecting the transfer case which solved the noise drivability issues…but just carrying dead weight.
I am ready to fix it now. Looking for replacement transfer case |
04-11-2022, 08:06 AM | #14 | |
Rep 24
