2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Can't plug OBD reader to the port
      02-13-2024, 02:28 AM   #1
mikola
mikola's Avatar
Azerbaijan
Drives: BMW 528i
2016 BMW 528i  [9.00]
I've been trying to insert my obd2 reader into the obd2 port without success. It feels like the reader's lips are thicker than the groves in the port. I've used this reader in my Mercedes and never had an issue like that. Aren't the socket size and thickness standard? I'm posting both the reader and the port pictures:
The obd2 port.
The reader
      02-13-2024, 03:34 AM   #2
NikMN
Drives: BMW F10 n63tu
Looks like port is pushed into the dash. Remove lower dash panel and clip it back.
      02-13-2024, 10:26 AM   #3
mikola
mikola's Avatar
Azerbaijan
Drives: BMW 528i
Found this post in the f87 forum that had a similar problem
      02-13-2024, 02:56 PM   #4
Qsilver7
Qsilver7's Avatar
Drives: F06 650ix GC / F15 X5 50i
The obd2 port.
Attachment 3386871
What is the piece highlighted in the pic below? It looks like something is blocking the OBD diagnostic port. Did something break off? The area with the red arrows looks like it won't allow the diagnostic socket to be pushed in to connect.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
      02-13-2024, 04:24 PM   #5
NikMN
That's not it.
      02-14-2024, 12:01 AM   #6
mikola
mikola's Avatar
Azerbaijan
Drives: BMW 528i
NikMN , you are right. It's for some reason been pushed into the dash. I tried to push it back without removing the panel(there's some opening near the obd housing with some foam inside it thourgh which I can access the back of the port). But it feels like it's been mounted that way because I wasn't able to move it outwards even a bit. The previous owner might have tampered with it. Looks like I'll need to remove the panel to see the whole picture there. Will let you know once I figure out.
      02-14-2024, 02:06 PM   #7
mikola
mikola's Avatar
Azerbaijan
Drives: BMW 528i
I'd taken my car to a guy for a spare key today. There he plugged his obd scanner with ease. Then I compared my reader with his, and everything seemed to be the same. Then I asked him to plug mine. He managed to plug it too but with some extra effort. And he had hard time removing it. So, the mystery stays mystery.
      02-15-2024, 09:16 AM   #8
Qsilver7
Qsilver7's Avatar
Originally Posted by NikMN View Post
That's not it.
But WHAT is it? The OBD port & socket is symetrical and the socket has to go around the OBD port...and what ever that solid piece is that's highlighted in the pic I posted...doesn't allow an OBD socket to go complete around the OBD port...which is why the OP probably couldn't press the OBD socket into the port.
If the OBD diagnostic port has been pushed in...perhaps that piece highlighted in red is part of some broken support piece around the diagnostic port?
