2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications how much is a new M5 exhaust (muffler back)?
      03-17-2013, 04:07 PM   #1
KBMWCT
Drives: 2013 550i xdrive
Anyone know what a new M5 exhaust goes for (mufflers back)? unfort they don't offer the performance exhaust for the 550 so what thinking about getting the m5 exhaust and m5 diffuser. will call dealer tomorrow, but was wondering if anyone happens to know offhand. assume it is cheaper than the dinan, etc.
      03-17-2013, 04:28 PM   #2
Edman951
Edman951's Avatar
Drives: 2014 i3, Capparis White
About 1039/ea
http://www.realoem.com/bmw/showparts...54&hg=18&fg=20
http://www.ecstuning.com/Search/18307848141/
Current, i3 Capparis White, Lodge interior
Ex- F10 550i Xdrive M sport, white
Ex- trade-in 2008 E90 M3
      03-17-2013, 05:23 PM   #3
KBMWCT
thanks!
      03-17-2013, 09:07 PM   #4
JRubin13
Drives: 2009 E92 335i/2012 F10 535i
There are a couple other companies that would probably provide you with an exhaust note/sound thats in the same ballpark if not cheaper. Probably sound even better...
      03-23-2013, 02:47 AM   #5
mdrobc13
mdrobc13's Avatar
Drives: Made in Bavaria
2021 BMW X3e  [0.00]
2016 BMW M4  [9.00]
Eissenman Race is about $2800. Great sound and fitment too. If you want an M5 I would also go suggest checking in the M5 posts forum or classified. Enough guys have modded out their F10 M5s for aftermarket exhausts that there's usual a set from an M5 or M6 for sale that you can probably pickup for under $1k. GL
'22 BMW M4 Comp (SSG/Black)
'16 BMW M4 (Shakir Orange/Black) - gone not forgotten
'15 BMW M3 (Black/Black) - gone not forgotten
'10 BMW X5M (Black/Black) - gone not forgotten
'08 BMW M3 (Space Gray/Black) - gone not forgotten
      03-23-2013, 06:29 PM   #6
rlh23
Drives: 2016 BMW 750i xDrive
Is there a fit issue with M5 exhaust on a 550i (non M package) or will M5 exhaust fit fine with the stock 550i diffuser?
      03-23-2013, 10:57 PM   #7
mdrobc13
mdrobc13's Avatar
2021 BMW X3e  [0.00]
2016 BMW M4  [9.00]
M5 exhaust should fit with no problems. They're basically same exhaust for v8 turbo engines so pipe diameter will be the same. Only issue you will likely find is rear difuser fitment. M5 outlets on the rear difuser lie more inboard than those on the M Sport 550i so IF you are able to source a set of OEM M5 mufflers you'll need to get the M5 OEM rear difuser as well to ensure proper alignment of your tips as they will then not exit properly on the OEM M Sport one as they won't align.
      03-24-2013, 08:27 PM   #8
Edman951
Edman951's Avatar
FYI, they are not the same pipe diameter.
550 is 70mm
M5 80mm
      03-24-2013, 10:07 PM   #9
mdrobc13
mdrobc13's Avatar
2021 BMW X3e  [0.00]
2016 BMW M4  [9.00]
550 is 70mm
M5 80mm
Thanks..interesting my shop had said they were but maybe they were saying that an adapter could be made to couple them quite easily. Thanks for the update.
      03-25-2013, 01:00 PM   #10
rlh23
Very helpful. Thanks. Might be cheaper to go with Eisenmann / Meisterschaft instead of having to buy M5 exhaust and diffuser.
      03-25-2013, 11:11 PM   #11
mdrobc13
mdrobc13's Avatar
2021 BMW X3e  [0.00]
2016 BMW M4  [9.00]
You can probably find a used M5 exhaust for $800-1000k from someone and the diffuser will cost you about $350 painted and add another $100-150 installed for them all so I'd think you could do it under $2k. An Eisenmann will run you about $2800 a Meisterschaft a little more but IMHO they will likely sound better than the OEM one. If you want PM and I can send you my contact I got my Eisenmann from [its my 3rd time I've gone to them to get me an Eisenmann for one of my cars so that should tell you that their customer service is outstanding]!
      03-26-2013, 12:16 AM   #12
kthankzbye
kthankzbye's Avatar
88
Drives: 2011 F10 550i, 2020 G05 40i
They go around 800-1000 for the full exhaust from the downpipes forward.
      04-04-2013, 09:22 PM   #13
KBMWCT
Now if I can just find someone to sell me one!
