2010 2011 BMW 5 Series Forum F10 F10 Rear Sun Shade Motor Only Replacement DIY |
07-13-2020, 10:29 PM | #1 |
Rep 1,909
This will just be a quick write up explaining how I sourced a replaced the sun shade motor for my F10. Eventually the motor will get weak and will not be able to close the sunshade without giving the arms a little assistance. Lubing up the sunshade rails did not rectify the issue. The dealer will just replace the entire sun shade unit for around $800 USD. Now I would like my sun shade to work but not for $800. I took my rear deck apart and removed the old motor from the sun shade. I google the manufacture part number and it looked like same motor was used for BMW, Mercedes, etc. I then found out that BMW sells a replacement sunshade motor for a E31 8 Series that fits out F10 and probably a few more BMW models. The motor even came with new hardware.
PN: 51461388215 Here is also an aftermarket motor for $25: https://www.aliexpress.com/item/4001...45f54c4d7xxe8J Last edited by Nickco43; 10-29-2020 at 02:34 PM.. |
09-21-2020, 09:47 PM | #2 |
Rep 648
no freaking way. Great recon work on this!!I've been on the hunt for a used unit but this offers a much better solution! Thank you so much for sharing your findings!
11' M-sport- 371 WHP-478 WTQ on stock PWG// DYNO COMING FOR Shuenk N55+ on 91oct/ BHP Intake/ IC/ CP/ DP/ Valved Mufflers/ David Shoup Tuning/ B58 Coils+N20 NGKs/ Walbro 450/ Helix OD/ xHP3/ G12 Brembos |
11-27-2020, 08:24 PM | #4 |
Rep 3
Removing black felt piece
How do you remove the black carpet like piece behind the rear seat? Any videos or step by step guide?
I’m trying to ultimately remove the shade for inspection |
04-30-2022, 08:38 PM | #5 |
Rep 1
Old Thread Revived with new photos/instructions
Fellow F10-enites, I recently acquired my 'new to me' 2013 F10 535i and quickly discovered the rear shade issue. Upon some research, found that the motor is usually in need of replacement. I could not find the Alibaba screamin deal mentioned earlier in this post so I sucked it up and bought a ~$200 unit from ECS tuning. Without a detailed instruction set on exactly how to do this, I used caution and some advice from other posts on other BMW series cars. What follows is my removal/install. ITS VERY EASY. There are, of course, a few tricks to help make this less painful. Of note - my ECS tuning motor replacement did not have the correct wiring (shown later). This was simply resolved by using the connection from my old motor. The only difference in the part numbers were the last two digits. Believe my stock was 059 and ECS was 039. Bottom line - if you have the OEM motor, just save the connections and you should be good. Verified mine works as intended.
Quick overview of steps involved. Details and pictures to follow: CAVEAT: I have rear folding seat so...I my first step was to fold them down (no rear seatback removal for me...). And for some reason, my photos would not post in portrait...only landscape. So some of these are sideways. If there's a fix for that, I'm all ears. 1. Remove rear seat bolsters. Pull from the top to release connection, then lift up to remove 'legs' inserted into the bottom. 2. Remove "Airbag" icon and unscrew torx screw to rear C pillar / air bag covers. 3. Remove 3x 8mm head bolts from trunk that bolt to rear sunshade. Photo 6. (only two bolts shown here. These are the only bolts in this panel, least on my car..) 4. Remove ~6x plastic pop rivets from rear deck near rear seat latch No photo. Simple rivets you remove the center stud then pry out. 5. Pull and remove rear shelf to flip over and lay on rear seat. (unplug speakers and motor connection before getting to the seat.) 6. Remove 3x torx screws holding motor to sunshade bracket and remove torx screw holding sunshade cam to motor sprocket. Caution - I slipped on mine a few times, stripped it, and ended up having to drill it out.... My favorite thing is to drill out bolts so this was just perfect. 7. Put everything back together! BIG TIP - when putting in the rear side bolsters, REMOVE the white plastic clip from the frame of the car. Insert it into the bolster panel you removed. Then when you have to push the bolster back on, it just snaps right in. Trying doing it without that step and you'll probably not ever get it to connect and might bend a few of the plastic pieces trying (ask how I know). Just FYI - Wiring that came with my motor. All in all, I couldn't believe how relatively easy this was. I usually break stuff when I don't have clear instructions and I just took my time and viola...no broken stuff! Hope this helps some of you looking to fix your sunshade! Cheers. |
walmark83.50 |
05-01-2022, 10:46 AM | #6 |
Rep 648
Thank you so much for this! Very detailed. I'll certainly take advantage of it.
