2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Need someone to reset code remotely
      08-03-2020, 09:28 PM   #1
khanmohammed
khanmohammed's Avatar
Drives: BMW M4 CS
I got a driver restraint malfunction issue because of different stage airbags but I got the proper airbag now and need someone to remotely code to fix it. Here are some pictures of the errors in esys
      08-04-2020, 11:20 AM   #2
Unspec
Unspec's Avatar
1300
Drives: 2015 BMW 535xi
Have you tried contacting Bimmertech? They do remote coding.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      08-07-2020, 07:58 AM   #3
dzz
Drives: 2015 BMW 535xi, MHD Stage 2+
2015 BMW  [0.00]
Do you know what needs to be coded? Since it looks like you already have a laptop and a cable to run ISTA, you can use the same laptop and hardware to install E-sys and code it yourself, it may be easier.
