03-19-2017, 03:05 PM | #419 |
Rep 162
03-20-2017, 08:00 AM | #420 |
Rep 1,170
Drives: M2 Competition, E30 M3 DTM
With lower emission rules i can hardly believe they put the S55 engine in it.
I hope the M2 CS gets the B58 with some M tweaks. Lower emissions even better throttle response. I have next to my M2 an M140i for the wife and i can tell you i rather have that engine in the M2 CS. S58 even better! |
03-20-2017, 04:57 PM | #421 | |
Rep 33
- i have seen the guy growing from M division sales man to manager over the past 8 years and he has good background info and nearly accurate future guesstimate. - He was very confident that the new M2 LCI is coming to the showroom this November with minor changes plus couple of new color same engines, and we won't see new engine change until 2019/20 model. More clear information (and maybe order) will spread between July and August. - a stronger more track focused M2 (CS or whatever it will be) is coming next year with new engine different suspension setup. Too early to tell the exact engine although he guess it may be the S55. About his price guesstimate: 16/17 M2 $73,000 (DCT sunroof fully loaded) 18 LCI M2 $73,000 may jump to $76,000 depending on what new upgrades it will get. 18 M2 CS not less than $85,000 . And i qoute his words " by all means it will not touch the M4 $100,000+ price barrier " . So my personal guess is 85-95k Note : the prices are local kuwaiti dinar KWD converted to USD. it may vary from different markets currency exchange, tax etc. Personally am waiting for the LCI and keeping my eyes on the CS, I don't need a super track modified M2. Am going to drive the car mainly on normal roads and highways. Last edited by Q8; 03-21-2017 at 03:38 AM.. |
03-20-2017, 06:19 PM | #422 | |
Rep 1,266
03-25-2017, 11:55 PM | #424 | |
Rep 1,266
bogeyman106.00 |
03-26-2017, 04:42 AM | #425 |
Rep 13,141
Physical constraints of a widebody M2: if an even wider M2 variant fails to physically pass through the production facility of the Leipzig factory, it's unlikely to be built (at least not at that facility). During M2 development, in order to check whether the M2 could be built at the Leipzig factory, dummy parts were stuck on an M235i to widen it to M2 prototype size spec and manually pushed all the way through the production facility (collision test). As it passed everywhere, production was materially possible (see also 11:00-11:42 in this M2 presentation video).
///M is art ↔ Artemis
03-28-2017, 06:31 AM | #426 |
Rep 13,141
If you expect the forthcoming M2 variant to feature a radical design: it will be more domesticated designwise than most are expecting. "Further progress" as Scott26 would say, or M2+, rather than revolution.
03-28-2017, 01:56 PM | #427 |
We've landed on the moon!
1449
Rep 906
Drives: 2011 1M (AW)
Artemis I believe you have said in previous posts that you think the CS(L) is not going to be intentionally limited production. What makes you think this? EOP schedule? If so, the E46 M3 CSL was a MY2004 while regular production continued to MY2006. 1M's were MY2011 while E82 production continued to MY2013. So if that is your reason, could it be that M GmbH follows suit with a mid production run CS(L)?
Also, others have speculated of a further iteration M2 GTS above an M2 CS(L). Is this based on anything or just purely speculation/hope?
03-28-2017, 04:57 PM | #428 | |
Rep 13,141
The M2 is selling like hot cakes. BMW can make more money with an M2 CS. The M2 CS benefits from all R&D, know how and costs that went into the M2, M3/M4 and 2er LCI + can also surf on the numerous base M2 accolades. BMW and your dealer will gladly sell you an M2 CS or M3/M4 if you hesitate between a base M2 and an M2 CS. The S55 engine (and its power output) will be the major difference between both brothers. Other differences I expect (apart from a higher price-tag): shaving off a bit of weight (some leightweight materials, but forget about 'leichtbau'; a manual transmission is a weight-saver for sure), an updated exhaust note and some design cues here and there to mark the difference with the base M2. Nothing radical apart from the use of the S55 engine, but enough as total package to read in M2 CS test reviews a zillion variations of the line "At last the M2 has arrived that got perfected the way BMW M must/should have initially intended it". Let's reason in a rational fashion: better not too many changes, as this allows:
Brief, an M2 sporting the S55 engine with a ± 400hp haircut and some changes here and there to mark its CS badge + an attractive price-tag for those who like to take a closer look at an M3/M4: say for yourself, with the M2 CS BMW got an ace up its sleeve (rather than an Audi/Merc jack of all trades, master of none specimen) to garner additional kudos from the enthusiasts for having released the best car of its class. On a final note: a EURO-spec base M2 6MT weighs 1495 kg (unladen) (see the specs here); for a word of caution about unrealistic weight reduction expectations, read what BMW M engineer Jürgen Schwenker replied in a Spring 2011 interview regarding the 1M (see here or here): "Q: Would it not have been possible to reduce the weight of the BMW 1 Series M Coupé to closer to 1,400 kilos instead of the 1,570 kilos achieved? After all, a number of body parts had to be redeveloped anyway. What would have been the additional cost for the customer if the 1,400 kg target had been reached ?Maybe BMW M is having a laugh upon reading the above. Or maybe they will mildly smile.
03-28-2017, 11:37 PM | #429 | |
Rep 11,785
BMW has done this with the E30 M3 sport EVO - final year of production E46 M3 csl - E92 M3 GTS , CRT 1M At times BMW has brought a hot model towards the beginning of the model run. E36 M3 CSL E36 M3 EVO F80 M4 GTS Bringing out a hotter model at the end of the life cycle occurs due to development of the motor and the Chassis. It also tends to function similar to an LCI refresh because of the extra bump in publicity/additional mods/additional Performance. The folks down the way at Porsche do the same thing right ?? Cayman Cayman S Cayman GTS Bam Cayman GT4 at the end of the run. So.. indeed we are hoping that BMW Provides some Further progression ala an M2 GTS. |
03-29-2017, 12:48 AM | #430 |
Rep 1,266
Artemis As always, very useful information and highly appreciated.
M3 Adjuster If I get the CS and you buy a CSL/GTS a couple years later, you and I'll have problems. The M4 GTS did not come at the beginning of the model, It came out towards the middle which is right about the time the CS is coming out. If BMW M was working on a GTS/CSL, we should know about it by the time the CS comes out... Right ?? It's going to kill me if the CS comes out and I see spy shots of something resembling a possible CSL/GTS. I waited too long and resisted way too many temptations for this car. Just 3 weeks ago there was a certified 2016 lightly used (13K miles) BMW M4 with complete XPEL, some M performance parts and a manual transmission for 58K at the local dealership. It was Yas Marina blue with the carbon fiber interior trim which is how I would've ordered it if I had the chance. It was a no haggle price but very attractive at that price point. I somehow walked away saying to myself that the best things in life come to those who wait. I just hope that the CS is not just a 400 HP bump up with some cosmetic changes. It's got to be more than that. It would be coming out at a time when the new GT4 RS could be out and the Audi TTRS would have already established itself. I was reading an article that BMW just lost it's top position to Mercedes last year. BMW is apparently planning on releasing a plethora of new products in the next few years to get back to the top. The M2 CS has to be one of those that pulls people away from the TTRS and makes the GT4 RS people think a little. |
M3 Adjuster7909.00 |
03-29-2017, 11:27 AM | #431 | |
1449
Rep 906
Point being it seems like there has been some history of the hot model coming out in the middle of production schedule. Just because there is room at EOP doesn't mean that it's going to happen. Not trying to start an arguement, just trying to see if anyone has any evidence to support a GTS level M2 other than the fact that there is room at EOP. F87 M2 is 2016 - 2020/2021? with the CS speculated to be a MY2019 (NA)... So if there is to be an even more hotter version it would need to be a MY2020 or MY2021. Seems a little bit rushed.
03-29-2017, 03:30 PM | #432 | |
Rep 11,785
The BMW E46 is the fourth generation of the BMW 3 Series range of entry-level luxury cars, and was produced from 1998 to 2006. Clearly then a model made in 2004 is not the middle of the production run. ( you considered the full model run for the 1 series but only referred to M3 model years for the E46 3 series) the 1 series was manufactured from 2004 to 2011 (2013 for certain models in Europe) once again.. note timing.. both the E46 M3 CSL and the 1M came out in the second from the penultimate year of series production. regarding your question of " evidence" There is ZERO confirmed evidence of an M2 beyond the CS. BMW typically doesn't ANNOUNCE their plans for future models within a lineup until AFTER prototypes are spotted. so why do some of us feel that there is going to be another model..? Thhis is RUMOR thread after all .. ? Regarding your comments of " rushed " to squeeze in another model after the CS..... there was a whole lot of " rushing" or should we call it " milking" ? with the E90 M3. The BMW E90/E91/E92/E93 series is the fifth generation of the BMW 3 Series range of entry-level luxury cars, and was produced from 2004 to 2013 BMW announced the M3 GTS in November 2009 (4 years from end of run) The M3 CRT (Carbon Racing Technology) was announced in June 2011 as a 2012 model In mid 2012 the BMW M3 Limited Edition 500 was launched in the UK The DTM Champion Edition was produced from February 2013, in a limited number of 54 cars, the same number as BMW's victories in DTM. In Germany, the price started at €99,000.00 including VAT. The M3 Lime Rock Park Edition was a US specific model, with a production limited to 200 cars, all painted in Fire Orange. All 200 of these were 2013 vehicles. so.... 4 different variants in the last 2 years.. perhaps for different markets... In other words.. I and @Artemis are not going to ASSUME that BMW is done when it comes to the M2. The US has received the following Stock M2 M2 ZL5 - 150 models - note this came out with ZERO FANFARE OR CONFIRMED ANNOUNCEMENT. M2 CS (upcoming) M2 further progress? we shall see. if you are looking for a CS.. then nothing should stop you from getting one.. Some of us would like to see BMW apply the GTS treatment to the BMW M2. Take a look at the BMW M2 Safety car and see how little it differs from an M4 GTS.. roll cage.. check! no rear seats... check! performance exhaust... check! water injection ?? three way adjustable suspension ? Check! carbon fiber brake package.. check! front aero.. check! rear aero.... check! Still potentially being developed at every single race track it goes to as a pace vehicle? ... CHECK! personally.. I'm just waiting for them to put a window sticker on a model that I ALREADY see circulating race tracks. And I don't think it would take much at all to move into production - just like the ZL5 Last edited by M3 Adjuster; 03-29-2017 at 07:46 PM.. |
04-03-2017, 09:33 AM | #433 | ||
Rep 4,255
///M Power
04-08-2017, 03:10 PM | #435 |
Rep 475
Drives: 1///M Coupe & ///M2 CS DKG
News spy shot whit largest bodykit ?
: Happyanim: but no carbone-roof or GTS bonnet and GTS mirror : Mad0259:
- Série 1 ///M BSM - |
04-08-2017, 05:33 PM | #436 |
Rep 13,141
Some interesting info surfaced in the M2 section of the German forum '2erTalk' (sources: here, here and here):
Below: screenshot shows that the M2 CS is scheduled to go into production in March 2018 at the BMW Leipzig factory (source: here) (note 1: "F87CS" is mentioned, rather than "F87COMP" or "F87COMPETITION"; note 2: where is the F87 M2 LCI ?!):
04-08-2017, 05:40 PM | #437 |
Rep 344
04-08-2017, 06:52 PM | #438 | |
Rep 2,720
production in July 2017.This list is showing that there won't be an LCI M2 starting production in July. |
04-08-2017, 07:06 PM | #439 |
Rep 1,266
So what I've gathered so far is that there will be an M2CS. The evidence for that is the production schedule and mostly all the cars that we see running around the nurburgring.
Where/What is the evidence for the M2 GTS ? I am trying to see if there was anything other than someone telling(guessing) that there will be an M2 GTS in 2019. Also, does that screenshot of the production schedule tell us if the M2/M2 LCI will also be produced while the M2 CS is being produced or does it say that it will be a replacement ??. It looks more and more like there won't be an M2 LCI and that the M2 CS will replace the M2/M2 LCI. |
04-08-2017, 07:26 PM | #440 | |
Rep 1,266
This is either a duplicate set of photos from when the car was first spotted testing around the ring or there might be changes under the hood that we do not know about. |
