2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Left turn signal and Daytime/Parking lamp malfunction
      08-14-2017, 09:46 AM   #1
ALPWhite
Drives: 2013 Alpine White 535iX MSport
Morning all!
Started the day with this error, drivers side blinker does not work (blinker sound is very quick, rear taillight as well as side fender light blink quickly) BUT when signaling right, both front blinkers turn on as if I put the hazards on.
Halo rings are working fine, did not test normal driving lights as I forgot to check but how many bulbs can the cornering lights have? I assume it should be just one that operates for both turning and hazards no?
Current: 2013 F10
Previous: 2007 E90
Previous: 1994 E34
      08-14-2017, 01:44 PM   #2
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Does it give you the option to reset it? I just got the seat calibration message and I'm wondering if it has to do with putting the carpets back?
      08-14-2017, 05:14 PM   #3
ALPWhite
Well... I went back outside to see and the errors are gone. Everything works as it should. . I will cancel my BMW appointment for now and if it comes up again I will take it in, chalking it up to an electrical gremlin for now.
I am sure you Googled it but check out this thread about seat calibration, looks like moving the seat front/back etc might solve your issue.. http://www.bimmerfest.com/forums/sho...d.php?t=612600
Current: 2013 F10
Previous: 2007 E90
Previous: 1994 E34
      08-15-2017, 09:32 PM   #4
abhaxus
Drives: 2012 550i M Sport
I had a similar error (same turn signal problems, plus adaptive headlights on my case) on my 2012 550i. It happened to me every time I started the car one night, and I realized that I hadn't booked my car up to my battery tender in a few weeks (the ctek version of the official BMW one). I had an appointment a few days later for an oil change at the dealer do I figured I'd bring it up. Lo and behold the error went away. At the dealer they said I showed several high battery discharge codes in the past but nothing currently. The issue has not returned now that I've been more diligent at hooking it up to the ctek if I have a few days of short drives.
I read the N63 is notorious for battery issues so that's why I bought the ctek. It also seems to help with my wife's Mazda CX-5 which I think has the same charging behavior as the BMW efficient dynamic crap. Her car idles roughly sometimes if it goes for a few weeks without topping up.
ALPWhite137.50
      07-07-2018, 09:02 PM   #5
bgray1157
Drives: 2011 BMW 535I MSPORT
My Adaptive Headlight Malfunction is on...left turn signal malfunction, daytime/parking lamp malfunction, headlamp vertical aim control malfunction. Was in shop for hail damage, dent removal. When I picked up car and started it the Adaptive Headlight Malfunction was on dash. I told them was not like this prior. They took to a self service high pressure wand car wash and they put too much water and pressure on left side which is why all the issues. I tried to replacing the headlight that was out twice with H7 SyLvania and it still isn't working. I have had errors before...2 low beams out and 1 high beam and I replaced myself and all was great a year ago. My major delima is I cant locate or get to the left blinker to replace it. BEFORE I did anything I dried everything completely and it sat in the sun for a solid week. There are no signs of any water, moisture anywhere. I don't understand why 3 issues popped up like this. Could my settings be messed up? They also took it to have a new windshield installed which they calibrated it. 61 Female very frustrated. Oh, and I wanted which out to my new LED headlights but can't until this is cleared up. Secondly, the darn LED plug does not match up to my headlight plug, uggggh
      07-11-2018, 07:56 AM   #6
TJBentley
TJBentley's Avatar
Drives: '12 528xdrive
You need a new headlight module. Even though it's all dried up the damage is already done. I'm pretty sure the water caused corrosion on the headlight module. You can access it from behind the light in the wheel well.
      07-11-2018, 10:28 AM   #7
bgray1157
Thank you for the feedback. I was pretty sure that was going to be answer.
      08-08-2018, 07:36 PM   #8
sur135
Drives: F10
I have the same issue. Just purchased a new module from ebay. Replaced it and everything, but errors still appear on dashboard, no change. The only reason would be coding. Do not know where to start. I'm brand new to this so would appreciate all the hand-holding I could get. Please help
      08-09-2018, 01:50 PM   #9
TJBentley
TJBentley's Avatar
Have to get it coded by a Bmw shop
      08-09-2018, 10:38 PM   #10
sur135
Drives: F10
Have to get it coded by a Bmw shop[/QUOTE]
Do you think Carly obd2 would work?
      08-11-2018, 07:52 PM   #11
TJBentley
TJBentley's Avatar
Do you think Carly obd2 would work?[/QUOTE]
I believe you need ISTA/P
Expect a shop to charge to $100-150
      08-12-2018, 09:15 AM   #12
RJ307
Drives: BMW E39
High pressure washer getting inside the headlights/module? Does anyone know if that means you can't really use a high pressure hose at the car wash to wash the car down and wash off bugs/major dirt after a long drive? That seems pretty bad.
      08-07-2019, 11:02 PM   #13
katyortan
Drives: BMW 5 Series F10 Pre-Facelift
I think you need to replace headlight driver module I have checked real oem catalog but not sure which one you need this one https://xenons4u.co.uk/bmw-tms-headl...6-7267045.html or https://xenons4u.co.uk/bmw-tms-headl...5-7274400.html as I am not sure what is difference between to be honest LOL
      09-06-2020, 10:00 AM   #14
THamblin528i
Drives: 2012 BMW 528i M Sport
Hi all. I’ve got the same problem as in the original post. Left turn signal malfunction. Fast blinking left turn signal with no front Turn indicator working but both front flash when I turn my right hand signal on just like hazards. Was there ever a resolution or anyone else experienced.
PS I have also changed both TMS modules and attempted to re initialization in ISTA+
      10-21-2021, 07:42 AM   #15
harveje
Drives: 2012 528i X
Hate to revive an old thread but the "Left turn signal and Daytime/Parking lamp malfunction" comes and goes on my 12 528i. Very sporadic, I can clear it and it'll eventually come back, all lights and markers work up until the error then hyper flash until I turn car off and restart. With lights and markers working would this be a module? and if so would ne1 know a part number and re initialize procedure? I have some software.. Thanks,
800FC7
Raw code: 800FC7
ECU: Central module (in driver's footwell) (FRM)
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear
============7==============
800FD0
Raw code: 800FD0
      10-21-2021, 08:51 AM   #16
musclesmarinara75
musclesmarinara75's Avatar
2013 535 XDrive  [9.75]
Originally Posted by ALPWhite View Post
Morning all!
Did you check the blinker fluid?
cdmulders326.50
      10-22-2021, 02:55 PM   #17
Attachment 2725902
      10-25-2021, 07:47 AM   #18
harveje
Drives: 2012 528i X
Ha, I must be past the 6K blinks threshold. Time to R&R the fluid I guess.....
      02-19-2022, 09:17 PM   #19
anc4
Drives: 2013 528i x drive
how did you resolve your turn signal issues? I have the exact same malfunction
thanx in advance
      02-20-2022, 04:49 AM   #20
vern321
Drives: 2014 530 D M-Sport
I had exactly the same issue with the mine, BMW had to replace the Headlamp ECU on that side, same issue water damage.
      02-20-2022, 10:48 AM   #21
OnlyGerman
OnlyGerman's Avatar
Drives: F15, F13, F10, E60
Headlight can be removed without removing bumper. Removed mine and sent to be repaired
      02-23-2022, 06:13 PM   #22
anc4
i replaced the control module on both headlights, purchased new aftermarket modules, do i need to code them? how?
