2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums F10 / F11 5-Series Photos - Video - Media What did you do to your 5 series today?
      08-09-2021, 08:32 PM   #2399
Jer_i_miah
Jer_i_miah's Avatar
Drives: BMW 535i
Originally Posted by Sylverlee View Post
Originally Posted by Jer_i_miah View Post
Not an upgrade, but definitely appreciated. What a difference.
What difference do you notice?
The noise is the most blaringly obvious difference, however mine was really plugged up with dead leaves and pine needles, so the amount of air that comes out is nearly double, and the smell is SO much better.
      08-10-2021, 04:38 PM   #2400
Unspec
Unspec's Avatar
1300
Drives: 2015 BMW 535xi
Finally got around to finishing the last of the comfort seat retrofit. Ran wire inside the door and spliced into the can lines for the side view mirror, since there is no other can line in the door if your car never came with memory passenger seats. The hole for the switch panel is actually punched out after manufacturing the door panel, so you normally need a special tool, but I traced out the driver side and free handed it. Not the prettiest hole in the world, but once the switch is installed it looks pretty OEM.
Also added a USB C PD port with data pass through, replacing the 12v socket under the glovebox. Allows me to still have wired android auto to my carlinkit MMI box, but also have USB C PD fast charging. Pretty trick, huge shout out to breakitout for the parts.
2015 BMW 535xi
ISTA VM Setup/Tutorial
cdmulders326.50
      08-14-2021, 07:05 PM   #2401
asian
Drives: F11 535i
Dam son this is good!
I wish AA was wireless.. would push me to get something/install my headunit sooner
      08-15-2021, 10:35 AM   #2402
Unspec
Unspec's Avatar
1300
At least for the MMI unit, there is wireless android auto for my unit. It's just that it's kind of laggy and feels like it operates at 15fps while wired is at 30fps.
2015 BMW 535xi
      08-15-2021, 08:45 PM   #2403
spielnicht
Petrolhead
spielnicht's Avatar
440
My customized steering wheel from Coby Wheel arrived and installed. I'm so happy with it and breaths a new life into the car. Highly recommend these guys.
2024 X3 M40i
2014 550i
2008 Z4 3.0si 6MT
2011 Z4 35si (sold)
      08-15-2021, 10:43 PM   #2404
SWFLf10
SWFLf10's Avatar
Got a chance to replace my engine and transmission mounts. It took most of the day, but after learning from my mistakes, I am confident I could do it in just a few hours now, if I ever have a need to do it again in the future.
      08-19-2021, 07:27 AM   #2405
spielnicht
Petrolhead
spielnicht's Avatar
440
Absolutely last mod on the car for the forceable feature. G11 caliper upgrade. Will post installed pics on the weekend once wheels are washed. Color (Sky Blue) is coming across a bit off in the photos, but it's a 100% match to the light blue in the BMW emblem. I wanted the calipers to be powder coated blue, but not anywhere close to Estoril blue.
Still going back and forth on decal (BMW vs Brembo vs nada). Not considering "M" for the same reason I stayed away from Estoril blue.
Can't thank Unspec enough for all his support on this mod.
If anyone is in the DMV, NV Coatings is the place to go for powder coating. They also did the 343m wheels I have and their work and customer service are tops.
2024 X3 M40i
2014 550i
2008 Z4 3.0si 6MT
2011 Z4 35si (sold)
Unspec1299.50
      08-19-2021, 07:50 AM   #2406
Gjohnson7
Gjohnson7's Avatar
255
Drives: 11' BMW 535i, 12' Lexus RX350,
2011 535i  [0.00]
Nice find on the G30 calipers. I've been keeping my eyes open for a set, but they have been hard to find for a good price.
Checkout my YouTube channel, Like and Subscribe. https://www.youtube.com/user/Gjohnson7771
MHD Flash, RVG Catless DP, RVG CP, RVG Boost Pipe, Walbro 455 LPFP, Style 433 Wheels, BC Coilovers, Ebay Strut bar, M-Sport Front Conversion, RVG FMIC, 6WB Cluster.
      08-19-2021, 01:47 PM   #2407
SWFLf10
SWFLf10's Avatar
I've been staying busy upgrading/performing maintenance before I start traveling again for the fall work season. Still have more I want to do, but I don't know if I'll have time before I have to head out of town again. Here's what I've now gotten accomplished:
Front struts/spring pads/bump stops
Front sway bar links
Front upper control arms upgraded to negative camber version (cheaper than Dinan, but supposedly the same spec)
Vanos solenoids
Spark plugs/coils
Cleaned MAF sensor
Cleaned afe dry air filter
      08-19-2021, 07:43 PM   #2408
marek555
marek555's Avatar
Estonia
36
Drives: BMW F10 535d, BMW E46 328i
Installed B pillar ambient light:
      08-19-2021, 07:47 PM   #2409
marek555
marek555's Avatar
Estonia
36
I have done a lot work for my EU spec F10 535d, I am thinking starting dedicated thread for my car. So, if I get some likes for this post, I will start my own thread, if not, there is no intrest, so I will not bother. But I will be warning You, there will be a lot pictures (maintenance, mods, repairs) in my thread, if You like this post
      08-20-2021, 12:59 AM   #2410
asian
Drives: F11 535i
Niceeeeee. making me look at brakes now
      08-22-2021, 12:55 AM   #2411
550bye
550bye's Avatar
Drives: 2011 550i
2011 BMW 550i  [5.67]
Digging the new roundels, forged carbon and no it's not an overlay or vinyl. Took a minute to get made but totally worth it to me
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R.
      08-28-2021, 03:57 PM   #2412
ultraboosted
ultraboosted's Avatar
Drives: 2012 535i xDrive M-Sport
Carbon fiber trim upgrade
      08-30-2021, 04:22 AM   #2413
TuckerE36
TuckerE36's Avatar
50
Drives: BMW 550i M Sport
Hit 40k miles on the F10 today, idk why it’s so depressing watching the odometer go up lol
2014 BMW 550i M Sport- Tuned by Matt @Cedar Performance-Daily Driver
2016 Audi Q5 3.0T Prestige-Weekend Warrior
2008 Infiniti G37S Coupe 6MT-RIP
2015 Lexus RC350 FS-SOLD
      08-30-2021, 07:45 AM   #2414
OnlyGerman
OnlyGerman's Avatar
Drives: F15, F13, F10, E60
That's awesome
      08-30-2021, 09:17 AM   #2415
ramman434
Drives: F30 335i
Attachment 2684282
Just wait, I'm about to hit 79k and am taking a 1600mi round trip road trip tomorrow.
'16 Carbon Black Metallic F10 535i M-Sport - TOTALED 11/21/21
'13 Black Sapphire Metallic F30 335i M-Sport - unknown charge pipe, MSport Exhaust, 20" 405M wheels, $61k MSRP, CF M4 Mirror caps & Spoiler, NGK plugs, Dinan Coils, BMS intake
      08-30-2021, 11:41 AM   #2416
marek555
marek555's Avatar
Estonia
36
Originally Posted by OnlyGerman View Post
That's awesome
Thanks It is cool little mod that F10/F10 never got from factory.
      08-30-2021, 11:43 AM   #2417
OnlyGerman
OnlyGerman's Avatar
Hit 40k miles on the F10 today, idk why it's so depressing watching the odometer go up lol
Attachment 2684282
Have you considered the 6WA cluster upgrade?
I went from the base cluster to the 6WA, it was pretty cheap and looks much nicer. 6WB would be nice but still so $$$.
      08-30-2021, 02:34 PM   #2418
Got a how-to??? That looks like something I'd like to do.
      08-31-2021, 02:06 PM   #2419
spielnicht
Petrolhead
spielnicht's Avatar
440
If you're interested TuckerE36, I have a 6WA that I'll sell for $150 but it does need to be virginized.
2024 X3 M40i
2014 550i
2008 Z4 3.0si 6MT
2011 Z4 35si (sold)
      08-31-2021, 02:55 PM   #2420
addy27
Drives: F10 550i
I can virginize that cluster as long as its 2015 or older or I can recommend a really good retrofitter based out of LA who can do so on basically all Fxx cars no matter the year.
