2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications 2011 528i drivetrain malfunction HELP
      01-25-2024, 05:43 PM   #1
keys2mybimma
Drives: 528i
Sorry for the long post guys but I got the dreaded drivetrain malfunction error message on my screen along with a plethora of other codes pulled from my bluetooth scan tool. It's also saying that my battery is discharging...but it's less than a year old. I registered it with my bluetooth ODB-II....could that be why. Was told that if I charge the battery all codes would go away BUT was also told that if I replace the crankshaft sensor...that could solve all my issues as well. Not sure where to start here...please help! Thanks in advance!
============1==============
P0335
Raw code: 0335
ECU: Engine control unit
Status: Confirmed
Crankshaft position (CKP) sensor - circuit malfunction
Crankshaft Position Sensor "A" Circuit
============2==============
P0727
Raw code: 0727
ECU: Transmission control unit
Status: Confirmed
Engine RPM input - no signal
Engine Speed Input Circuit No Signal
============3==============
CF2C21
Raw code: CF2C21
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested
============4==============
4209A4
Raw code: 4209A4
Status: Pending, Confirmed, Test failed since last DTC clear
============5==============
213601
Raw code: 213601
ECU: Engine control unit #1[Archive (inactive)]
Status: Confirmed, Test failed since last DTC clear
============6==============
20A902
Raw code: 20A902
Status: Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle
============7==============
160001
Raw code: 160001
Status: Test failed, Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested
============8==============
1C3101
Raw code: 1C3101
============9==============
20AA04
Raw code: 20AA04
============10==============
8020C8
Raw code: 8020C8
ECU: IPDM/Junction box (JBBF)[Archive (inactive)]
Status: Test failed since last DTC clear, Test not completed during this operation cycle
============11==============
8020E6
Raw code: 8020E6
============12==============
8020E7
Raw code: 8020E7
============13==============
8020E8
Raw code: 8020E8
Status: Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear
============14==============
C90D74
Raw code: C90D74
============15==============
D35476
Raw code: D35476
ECU: DSC/Traction control
============16==============
801C15
Raw code: 801C15
ECU: CAN gateway
Status: Pending, Confirmed, Test not completed during this operation cycle
============17==============
801C20
Raw code: 801C20
ECU: CAN gateway
============18==============
48010F
Raw code: 48010F
ECU: Suspension/Dynamic management
============19==============
D02D54
Raw code: D02D54
============20==============
D01476
Raw code: D01476
ECU: Suspension/Dynamic management[Archive (inactive)]
============21==============
481F8B
Raw code: 481F8B
ECU: TPMS
Status: Test failed, Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle, Warning indicator requested
============22==============
481F8C
Raw code: 481F8C
ECU: TPMS
============23==============
481F8D
Raw code: 481F8D
ECU: TPMS
============24==============
481F8E
Raw code: 481F8E
ECU: TPMS
============25==============
481FC6
Raw code: 481FC6
ECU: TPMS[Archive (inactive)]
============26==============
D35476
Raw code: D35476
ECU: ABS/DSC
============27==============
D52D54
Raw code: D52D54
ECU: Steering
============28==============
D51476
Raw code: D51476
ECU: Steering
============29==============
930769
Raw code: 930769
ECU: Car access system
============30==============
93076A
Raw code: 93076A
============31==============
93076B
Raw code: 93076B
============32==============
93076C
Raw code: 93076C
ECU: Car access system[Archive (inactive)]
Status: Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle
============33==============
801A4A
Raw code: 801A4A
ECU: Center roof module
============34==============
B7F30F
Raw code: B7F30F
ECU: Flexible bus interface
Status: Warning indicator requested
============35==============
B7F311
Raw code: B7F311
============36==============
B7F313
Raw code: B7F313
============37==============
B7F315
Raw code: B7F315
============38==============
B7F316
Raw code: B7F316
============39==============
B7F318
Raw code: B7F318
============40==============
B7F319
Raw code: B7F319
============41==============
B7F31A
Raw code: B7F31A
============42==============
B7F322
Raw code: B7F322
============43==============
B7F323
Raw code: B7F323
============44==============
800FC7
Raw code: 800FC7
ECU: Central module (in driver's footwell) (FRM)[Archive (inactive)]
============45==============
800FC3
Raw code: 800FC3
============46==============
800F2F
Raw code: 800F2F
============47==============
800F41
Raw code: 800F41
============48==============
800F92
Raw code: 800F92
============49==============
800FC8
Raw code: 800FC8
============50==============
800FC9
Raw code: 800FC9
============51==============
8011FD
Raw code: 8011FD
ECU: Climate/heater/Air conditioning
============52==============
801253
Raw code: 801253
ECU: Climate/heater/Air conditioning[Archive (inactive)]
============53==============
801222
Raw code: 801222
============54==============
E71429
Raw code: E71429
============55==============
E71431
Raw code: E71431
      02-17-2024, 09:36 AM   #2
NAS2
Drives: 2011 F10 528i
We’re you able to figure out what caused the Drivetrain Malfunction/DSC Malfunction? What component part or sensor was the issue to set off the car.
������Update������
If you have ista+ and this code pulls up OXCD8E02 or CD8E02 start checking all the wiring in the engine bay. Your EGS Wiring harness may have a defect of some sort that is creating a Drivetrain/DSC Malfunction CURRENTLY DOUBLE CHECKING THE WHOLE ENGINE BAY IT MAY BE WATER DAMAGE COMING FROM THE COWL ON THE PASSENGER SIDE WHERE IT CONNECTS TO THE FUSE BOX IN THE GLOVE BOX. I will keep updating till it is resolved I have been on mission with this for a week already.
