2010 2011 BMW 5 Series Forum F10 Installing new BOV tips ??? |
02-09-2024, 09:20 AM | #1 |
Rep 109
So Im 99% sure my factory diverter valve bit the dust after some beating on the car last night. It runs fine, drives fine, just down on power and I can clearly hear boost leaking the entire time as i drive under load. I was wanting to replace it anyway as it has 150,000mi on it. So my 535i is xDrive which im not sure is the main issue but I hear about swapping these out are a pain. Any tips, special tools I need to consider. Mind you I am very mechanically inclined and have a well equipped garage but its always good to hear from experienced fiddlers. Thanks
02-09-2024, 11:03 AM | #2 |
Rep 1,873
First thing I'd check would be the charge pipe.
ChiltiCoatl891769.00 |
02-09-2024, 08:37 PM | #3 |
Rep 435
Drives: 2016 F10 BMW 535i M Sport
Yeah, Great time to upgrade to Aluminum if you haven't already, and what Diverter Valves did you have in mind (I.E Brands?)
02-13-2024, 08:48 AM | #4 |
Rep 109
I already have the VRSF Charge pipe. And it was the factory diverter valve. It not only came apart internally, but had a huge tear in the orange rubber. I installed the Turbosmart kompact valve. WHAT A PAIN IN THE ARSE!!!. I had the old one out and ready in 40 min but getting the new one bolted in was a pain. The larger portion of the new one made it nearly impossible to get the bolts in. I did devise a plan after 4 hours of messing with it. Ill see how it goes once implemented tonight or tomorrow and it may be the saving grace on this install for others.
02-15-2024, 02:19 PM | #5 |
Rep 2,591
In the future, use long reach ball end hex. Made it farrrr easier.
I got the bolts to stay attached to the ball end by coating the ball end in some thick grease.
2015 BMW 535xi
02-16-2024, 08:13 AM | #6 |
Rep 109
So the infamous third bolt issue... I solved it for myself by going this route. I cut the hole open on the end like pictured. I then put the third bolt in by hand about halfway, slid the BOV in under the bolt, started the other two and boom. easy peasy
