2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications 2011 F10 535i
      11-05-2019, 07:03 PM   #1
ChaOZ
Drives: 2011 535i F10
Thumbs up 2011 535i f10 fueling issues
Anybody got any idea why after installing the Fuel-IT Flex fuel kit for my car when I turn it on the engine will start sputtering and eventually die. It will run for a bit I can accelerate and it will hold RPMs but when I let off its almost like it just runs out of fuel. *Note* I am also running the walbro 450 on my setup and have already ran it for a couple of days before I did the flex fuel kit and it worked flawlessly. Some of the codes that I get are ;
-DME Active Codes-
-CDB204 FA CAN message, (outside temperature, 0x2CA) missing
-10B104 outside temperature sensor signal: CAN message in error
-*DME Shadow(Inactive) Codes-
-11A301 - High Fuel Pressure after engine shutdown: Pressure too high.
-11A401- Fuel high pressure during fuel injection release: Pressure too low
-11B401 - Fuel high pressure or after enabling injection (2nd ambient condition set after delay): Pressure too low
      11-07-2019, 09:43 AM   #2
BimmerHausPerformance
BimmerHausPerformance's Avatar
513
Drives: 2011 535i 6MT
2011 BMW 535i  [0.00]
Sounds like you need to talk to the manufacture. Those messages from CAN are from a different ECU that I would think, have nothing to do with your fuel set up.
Tags
535i f10, f10 2011
