2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Cut power to cigarette lighter socket when car turns off
      10-15-2018, 01:52 PM   #1
OrcaPod
Drives: 2011 BMW F10 528i N52 engine
Hi all,
I have 2011 BMW 528i and was wondering if there are any way for one of the cigarette lighter sockets to stop drawing electricity once engine is off?
Can it be done with some coding and without re-wiring/messing with wires?
either front, armrest or rear-seat socket will do for me.
I d like to use either of them for dashcam and not to plug/unplug dashcam every time i drive. it seems that they still provide power with engine off.
Thank you!
      10-15-2018, 06:11 PM   #2
Originally Posted by OrcaPod View Post
Hi all,
Thank you!
I hardwired my radar detector using an add-a-fuse. You might try that route: it really isn't that hard.
I seriously doubt power to the outlet can be coded out. I guess you could wire in a switch...
OrcaPod73.50
      10-15-2018, 06:54 PM   #3
OrcaPod
Hi ezaircon4jc
Can you please share more details on how you did it?
Thanks a bunch!
      10-15-2018, 07:21 PM   #4
Hi ezaircon4jc
Thanks a bunch!
Sure...
I just ran the "phone" cord (that's the wiring for the V1) down the passenger side "A" pillar (what a pain in the keister THAT was to reinstall!!) and used an add-a-fuse to fuse #43 in the fuse box behind the glove box. You could probably just stuff the wires behind the "A" pillar trim piece without removing it; might have to pull back the weather stripping... The add-a-fuse keeps the "appliance" and main fuse on different circuits.
      10-16-2018, 08:29 AM   #5
OrcaPod
Thank you, ezaircon4jc !
      10-19-2018, 05:45 PM   #6
bake
bake's Avatar
Drives: 2011 F10, 2013 E93
The cigarette lighter is only powered for a few minutes after you turn off the vehicle. It is not constant power. So your dashcam will only run for about 8 mins after you shut off and lock your vehicle. I actually like this feature as my dashcam is powered the same way and it allows you to record footage for the short period after walking away from your car.
Bake
2011 Alpine White on Black 535i M-Sport
2013 Space Gray on Fox Red M3 Vert
OrcaPod73.50
      10-22-2018, 08:02 AM   #7
OrcaPod
Thanks a lot, bake, for the response.
It saved me from the extra work on add-on fuse. I'll try you suggestion.
      12-31-2018, 04:25 PM   #8
vault90
Drives: ‘12 535i xDrive/Sport
Hi all,
Thank you!
I plug my dash cam into the socket underneath the glove box. It's completely hidden that way and it only stays on for 5-10 minutes after the car shuts off.
OrcaPod73.50
