2010 2011 BMW 5 Series Forum F10 What did you do to your 5 series today? |
04-25-2020, 10:02 PM | #1761 | |
Rep 423
I painted them the same blue as my calipers, which was from an engine enamel paint. What's weird is I have some sort of secondary vent structure behind my grills that you don't have.
Checkout my YouTube channel, Like and Subscribe. https://www.youtube.com/user/Gjohnson7771 MHD Flash, RVG Catless DP, RVG CP, RVG Boost Pipe, Walbro 455 LPFP, Style 433 Wheels, BC Coilovers, Ebay Strut bar, M-Sport Front Conversion, RVG FMIC, 6WB Cluster. |
lsturbointeg9158.50 BurrNinja430.50 |
04-25-2020, 10:34 PM | #1762 |
Rep 1,254
Just did my
Rear brakes Akebano (fronts are still original and good with 52k miles) Flush brake fluid Oil change Liqui Moly Hand wash then Meguiars Hybrid ceramic wax Felt good by saving load of money
Ickdeep5720.50 lsturbointeg9158.50 |
04-26-2020, 05:45 PM | #1763 | |
Rep 14,522
heck yeah!!!
04-26-2020, 05:46 PM | #1764 |
Rep 14,522
oh damn look what came in!
ezaircon4jc4483.50 jayster0966209.00 |
04-26-2020, 10:46 PM | #1765 |
Rep 5,365
05-05-2020, 01:10 PM | #1766 |
Rep 96
Installed sequential mirror turn signals today, love em! I think I’m going to have to get some of the gloss black winged mirrors caps now.
Yes, I know she’s filthy, about to get a bath now. View post on imgur.com |
05-05-2020, 04:40 PM | #1767 | |
Rep 5,365
05-05-2020, 05:04 PM | #1768 |
Rep 96
I did it with the mirrors still on the car. It’s not difficult, just a little finnicky because you really don’t want to break anything while doing this.
I also chose to cut the connectors off the new turn signals rather than tear down the door panel unnecessarily just to clip that in. I also like to solder, lol. So basically I cut the connector off the new turn signals, cut the wires of the factory turn signal and soldered them together. 1) Remove the mirror cover, there are a few different threads about this but let me know if you need a hand. It’s pretty simple, basically grab from the part closest to the door, separate there and then carefully separate towards the outside releasing the clips. 2) Remove the mirror. This is best done by carefully tilting the glass as far down as it will travel and then CAREFULLY use a plastic trim tool to pry at the back between the tilted down glass and the mirror housing. The mirror should pop out. 3) If your mirror is heated, carefully pull the connector free of the clamp on the mirror back and separate the connectors. 4) My kit came with the appropriate Torx wrench to remove the screw that holds in the turn signal assembly. If you look down inside the housing, you will see which bolt it is. It must be removed from the mirror side of the housing (why we removed the glass). 5) To remove the original turn signal, you have to carefully free the bulky side (toward the inside of the housing). There is a retaining tab there that you need to move the turn signal past. The turn signal has a groove at the low edge that the lower mirror housing fits inside of. Using a plastic trim tool, carefully work to separate the turn signal from the housing and pull it free. 6) Chose to cut and solder/splice the new turn signal to the factory wiring or proceed to teardown your driver side door to access the connector. Reverse installation. |
ezaircon4jc4483.50 |
05-05-2020, 05:15 PM | #1769 |
Freude am Fahren
479
Rep 362
Drives: G26 i4 M50, F11 M550d, E70 X5
Garage List 2011 BMW E70 X5 xDr ... [0.00]
2015 BMW F11 M550d ... [0.00] 2024 BMW G26 i4 M50 ... [0.00] 2009 730dA [10.00] |
Went from black kidneys to chrome.
OEM+ customization is the way to go!
ezaircon4jc4483.50 cdmulders326.50 |
05-05-2020, 11:53 PM | #1770 |
Rep 965
05-06-2020, 10:12 AM | #1771 |
Rep 1,154
I typically always change rotors/pads i'm not a big fan of machining rotors, there by removing metal from the rotor surface....
its such a critical component, changing rotors each time you change pads is cheap insurance...imho |
05-06-2020, 06:03 PM | #1772 |
Rep 96
Took my F10 in to my body guy today. Initially I was just going to have him repaint/blend a door after a detailer sanded through the clear coat. I decided to also have him respray the hood as rockchips have taken their toll. He reminded me that it would be a good time to do the front bumper as well so I ordered a replica M Sport bumper.
View post on imgur.com It also came with fogs which I’ll be retrofitting as my SE did not come with fogs. Additionally, I’m having him paint and install an M Performance lip spoiler in gloss black. I’ll have the car back this weekend, I’ll be sure to post pics. Last edited by Themarkymark; 05-06-2020 at 08:57 PM.. |
jayster0966209.00 lsturbointeg9158.50 |
05-06-2020, 08:30 PM | #1773 | |
Rep 14,522
05-06-2020, 08:46 PM | #1774 |
Rep 96
05-06-2020, 11:14 PM | #1775 |
Rep 68
Drives: 2013 F10 535I / Lime Rock M3
Used 343M
Purchased a used set of M5 343M wheels for $600.00
My new Winter set - now I need summers |
05-07-2020, 12:33 PM | #1776 |
Rep 544
Hell of a deal!
Project Gamma Intakes / Project Gamma Catless Downpipes / Muffler Delete / DME Stage II Tune / H&R Springs |
05-07-2020, 06:40 PM | #1777 |
Rep 14
Wrapped my rails in prep for the roof to be wrapped when my vinyl comes in.. I always found it incomplete when folks wrap the roof but leave the rails untouched especially on white F10s
jayster0966209.00 |
05-07-2020, 11:21 PM | #1778 |
Rep 204
Quick oil change then a wash. Pollen managed to get in the garage and coated her a lovely green.
ezaircon4jc4483.50 OnlyGerman363.50 |
05-09-2020, 06:38 PM | #1779 |
Rep 221
This afternoon project. should not take long.
05-09-2020, 07:22 PM | #1780 |
Rep 14,522
Will you need to code it?
05-09-2020, 09:21 PM | #1781 |
Rep 221
05-09-2020, 09:25 PM | #1782 |
Rep 96
Nice! I'm going to do this, already have SAT coded, but I'm holding out to find a ceramic unit for a decent price.
2014 535i xDrive | MHD Stage 2+ | ER Catless DP | ER Charge Pipe | G-Plus Intercooler | Walbro 450 LPFP | Staggered 20” Avant Garde M359 |
jayster0966209.00 |
