2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Bootmod3 tune flash failed car wont start
      04-06-2021, 02:16 PM   #1
fstm5
fstm5's Avatar
146
Drives: F10 M5
Hello, so currently I have a 2016 550i that's tuned with bootmod and I have always had issues flashing tunes onto my car, it usually takes over an hour just to get one tune because of how much it fails and my dme goes into sleep mode, but usually I solve the issue by charging the battery and eventually it works, but this last time I've tried flashing a tune, it is not recovering at all, the battery was charged, I started tuning and it went to a couple percent than failed, so I tried again then it would not even go to a percentage, it would just try clearing the "vehicle ecu codes" and it would fail, and ever since then it has been doing the same thing over and over again and my car will not turn on. This is SUPER frustrating as I'm losing sleep over this, I even let my battery charge over night and no difference. I start the flash, it says "beginning writing block" then it goes to "Clearing codes on all vehicle ecu's" then it just fails, it does not even start, I've went down the entire checklist of what could be causing it to fail, I am using the bootmod wifi adapter that connects to the OBD and using my phone to flash, I am beyond frustrated because I am lost on what it is going on, if anyone can help out it would be wonderful, I have been on bootmod support talking to their team nonstop but we still have not figured out a solution. I even tried resetting the dme, no difference
      04-06-2021, 02:30 PM   #2
FdisFingF10
Drives: 2011 BMW 550i M Sport 6M
Did you try flashing stock file first? Anytime I bricked the car, I just flash back to stock. Then reflash. No guarantees.
Sleep mode? Keeping seatbelt on usually resolves that.
      04-06-2021, 02:39 PM   #3
fstm5
fstm5's Avatar
146
Drives: F10 M5
it's the same issue, same thing happens no matter what map I try to flash, I'm not sure if it's sleep mode or whatever it is, it is in a mode where I get a bunch of codes and the car does not start, But yes I can't even flash the car back to stock
      04-06-2021, 05:03 PM   #4
BimmerRalph
BimmerRalph's Avatar
16
Drives: BMW 535I M SPORT
2011 BMW 535I  [0.00]
Flash the car back to stock, turn the car back on leave it running for a minute or 2 then try again. ive had this happen to me a few times on my other BMW's.
2011 535i M Sport l ER Chargepipe l BMS Intake l Megan Racing Mufflers l RVG Catless Downpipe
Subscribe To My Youtube Channel!!
https://www.youtube.com/channel/UCuR..._as=subscriber
      04-06-2021, 05:15 PM   #5
fstm5
fstm5's Avatar
146
Drives: F10 M5
I physically cant, it is not working , it is giving me the same issue as it does with any other map
      04-10-2021, 11:10 PM   #6
AlpineweissF10
Drives: 2012 535i Xdrive
Have you tried to flash with a different device and/or cable? hopefully support can find a resolution.
      04-11-2021, 08:34 PM   #7
GrabacrOne
GrabacrOne's Avatar
178
Drives: F10 535i
Have you tried flashing using the ENET cable connected directly to your laptop? I switched to ENET-to-iPhone recently but had the issue where it didn't relock the DME when flashing back to stock. I went back to using my laptop directly and it worked fine, so it looks like there might be issues with the iOS or WiFi adapter methods.
Also, are you supporting your battery with a charger while flashing, or just charging up your battery beforehand? I run a 15 amp charger while flashing and I've never had any issues. I've had a flash fail and prevent my car from starting but once I used a battery charger, I was able to flash back to stock and retry successfully. I use a charger all the time now just to be safe. Also switch off A/C, headlights, put your seatbelt on, and don't open any doors while flashing to prevent the DME from going to sleep.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #578262 as a referral.
F10 535i M-Sport | Gone but not forgotten: G01 X3 xDrive30i M-Sport; F15 X5 xDrive35i; E70 X5 4.8i
      04-16-2021, 12:29 AM   #8
fstm5
fstm5's Avatar
146
Drives: F10 M5
***UPDATE***, I’ve been at work and unable to respond to this post, they ended up helping me out bootmod support, one of my dmes got deleted, I am not sure how but it somehow did, they needed to use a bmw diagonal tic program to get me back to stock map
      05-21-2021, 06:11 PM   #9
YaBoyMARC
Drives: F32 2015 435i
Did you have to go to BMW for this? how did you end up getting it?
Tags
bootmod3, tune
