2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Rod knock??
      06-28-2020, 03:54 PM   #1
Speedy38
Drives: Bmw 550i
Rod knock??
So had a strange noise coming from my N63 engine I first hear iT on a could engine and sound was gone tought is was coming from the passenger side wheel. Yesterday I hear this noise and I know now for sure its coming from the engine sound get louder if the engine is fully warmed up. Is this rod Knock?
Strange thing is engine is rebuild 4000 km back because it spun two bearings cylinder 3 and 5 so new bearings, crankshaft and many more parts and now this sound.
      06-28-2020, 06:05 PM   #2
BurrNinja
Drives: 2011 535i Xdrive
Do a video on the outside. Hard to tell while driving could be anything drivetrain, rotating unbalanced.
      06-29-2020, 01:43 AM   #3
Speedy38
Drives: Bmw 550i
On idle you hear nothing I only hear the sound on low rpm when the rpm is going up the sound is going up also when I let the gas of the sound is gone. I called the shop this morning and the gonna get the car for inspection.
BurrNinja263.00
      06-29-2020, 04:00 AM   #4
BurrNinja
Hope the best for your situation. Let us know update!
      07-02-2020, 10:09 AM   #5
Speedy38
Drives: Bmw 550i
Update, shop says sound didnt come out of the engine, but that the sound is from the passengerside front driveshaft.
Is it normal that a driveshaft fails after 140.000 km? had so many BMWs in the past never had a driveshaft failure at any of them.
      07-02-2020, 12:20 PM   #6
BurrNinja
Cv axle? Axles are wear and tear item. Possible for early failure to lasting a lifetime.
      07-02-2020, 12:52 PM   #7
Themarkymark
Drives: 2014 Imperial Blue 535i xDrive
I replaced my RF at around 77k miles and now Iím about to do my LF at 80k, they donít seem to make it much farther.
2014 535i xDrive | MHD Stage 2+ | ER Catless DP | ER Charge Pipe | G-Plus Intercooler | Walbro 450 LPFP | Staggered 20Ē Avant Garde M359 |
      07-02-2020, 01:32 PM   #8
Speedy38
Drives: Bmw 550i
thanks for the replies, shop orders a new driveshaft i hope everything is ok after that.
BurrNinja263.00
      07-03-2020, 10:39 PM   #9
BurrNinja
Usually failure point on the axles are the boots. They get fragile and rip. Loss of grease = faster failure.
      Yesterday, 05:27 PM   #10
Speedy38
Drives: Bmw 550i
Thanks for the info! Learning so much here
BurrNinja263.00
      Yesterday, 11:28 PM   #11
BurrNinja
Happened to me passenger front gave out, replaced both fronts and wheel bearing hub assemblys.
      Today, 10:37 AM   #12
ednyc2nc
Drives: 2008 BMW 335i 6speed
2012 535i xdrive at 72000 miles passenger side cv axel broken boot.....maybe the hub is bad also....
Copyright ©2000 - 2020, vBulletin Solutions Inc.
