2010 2011 BMW 5 Series Forum F10 Adaptive drive Front suspension sits higher |
09-21-2021, 07:48 AM | #1 |
Rep 808
I have a 2011 535i with adaptive drive and recently had the oil pan gasket replaced, so they had to drop some components of the suspension and recalibrate. The front now sits noticeably higher afterwards, to the point I notice the headlight aim is higher than before. Anyone experience this or know a remedy? I had the Indy reinitialize the suspension a few times but still the same
09-21-2021, 04:27 PM | #2 |
Rep 1,035
Did they tighten the suspension and sway bar bushings before lowering the car? If so, all the inboard bushings on the suspension need to be loosened and re-tightened with the car's weight on the suspension. Not doing this will cause the bushings to bind and add to the "sprung" rate of the front suspension, holding it at a higher ride height.
There are 10 bushings in total: 2 on each upper control arm (4 total) 1 on each lower control arm (2 total) 1 on each thrust arm (2 total) 2 on the sway bar (2 total, one on each side) Realistically they would only need to reset the bushings they removed or loosened during the process. Other than that I can't think of any reason why the car would sit higher after a service like that, especially if they didn't touch the shocks/springs in the process. |
09-21-2021, 04:32 PM | #3 |
Rep 1,035
Also, there are level/height sensors for the headlight aiming. If the tiny brackets that hold the sensor tie rod to the control arm got bent this could affect your headlight aim. Just a thought, since technically the headlights should adjust themselves to the new higher suspension position (auto-correct their aim). If they're aimed high/low from where they should be that bracket may have been bent or not replaced properly if they removed it (not sure why they would have to?).
09-21-2021, 04:37 PM | #4 | |
Rep 808
Also is it going it be a lot of work to readjust, or is access to loosen and tighten the bolts easy? |
09-21-2021, 04:51 PM | #5 |
Rep 1,035
Ideally a shop would have a drive-on style (4-post) lift for this job, the same kind used during alignments. This allows good access while keeping the car "on the ground".
The main undertray cover has to come off to give access, but that's a two minute job once the car is elevated. The lower control/thrust arm bushings are then accessible, and resetting them is a simple two-wrench job. The upper control arm bolts are more involved, but I can't see why they would have loosened those to get at the oil pan? I have no idea about the sway bar bolts since my car is not Adaptive Drive, but I can't see them being too much work once the undertray is off. If you follow BMW maintenance to the letter those lower control arm bolts should be replaced every time they're loosened, but I don't subscribe to that. If you do they're not expensive, and replacing them requires unloading the suspension, installing them loose, then torqueing to spec once the car is sitting on the ground again, preferably after being rolled forward/back and jostled around a bit to settle the suspension. If I had a hoist and an alignment rack I could easily do this in less than an hour, unless the Adaptive Drive sway bar bushings are a pain for some reason. This would still be less than a two hour job in my driveway... I just went through this very thing after lowering my '16 F10. |
09-21-2021, 04:56 PM | #6 | |
Rep 808
09-21-2021, 05:13 PM | #7 |
Rep 1,035
That's just the most obvious reason I can think of for sitting high.
If they don't have a drive-on style lift then tightening the bushings with the suspension loaded can be a pain. I did it on small service ramps in my driveway, tightening as much as I could to keep the bushings from moving, then jacking the car up and torqueing afterwards. Good luck, and let us know if that solves the problem. |
09-22-2021, 09:43 AM | #8 | |
Rep 808
09-22-2021, 09:50 AM | #9 | |
Rep 697
Drives: 2013 535xi
Good luck!
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) |
09-22-2021, 09:52 AM | #10 | ||
Rep 808
09-22-2021, 10:46 AM | #11 | |
Rep 2,588
2015 BMW 535xi
walmark85.50 |
09-22-2021, 11:09 AM | #12 |
Rep 1,035
