2010 2011 BMW 5 Series Forum F10 New Injectors Good For 600+hp |
06-10-2021, 10:46 PM | #1 |
Rep 1,230
Well god gave us a bonus. If your looking to upgrade turbos and dont want to do port injection these injectors just came out for the s55 but can be used for n55s as well. I just ordered a set. 1200cc factory injectors that will work for MHD and tuned by David Shoup. Can handle FULL E85.
N55 GENERAL
David Shoup Tuned Fully Built By Miami Engines/Project Motorworks Precision 6266 On Steroids |
06-12-2021, 10:38 AM | #2 |
Rep 1,442
Drives: 2011 535i 6MT
So you would just need an upgraded HPFP then, right?
06-13-2021, 08:47 AM | #4 | |
Rep 1,442
Oh, clutch/transmission upgrades too. |
06-13-2021, 10:44 AM | #5 | ||
Rep 64
My 15' 535xi was $22k +PS2 approx $4k +The $4k you mentioned +DP+MHD+Intercooler approximately $1.5k = $30k-$35k Pick up an M5 for $35-$45k…. Decisions decisions…. |
06-13-2021, 11:33 AM | #6 | |
Rep 1,299
Plus I don't think you will get an m5 with low mileage at the 35-45k price tag... probably be ready for some repair bills on that car. |
06-13-2021, 11:50 AM | #7 |
Rep 1,442
Agreed, It all depends on where you are at.
535 6sp 80k miles - 14,500 Used ps2 - 1450 Do all the work yourself… way ahead of the game! |
06-13-2021, 12:36 PM | #8 |
Rep 1,230
yes sir and more great news. Dorsch is coming out with stage 3 pump. 115% increase. That means more flow than the fx 180.
N55 GENERAL
06-13-2021, 02:32 PM | #9 |
Rep 1,299
06-13-2021, 03:53 PM | #10 |
Rep 1,230
dam!
N55 GENERAL
06-14-2021, 10:58 AM | #11 |
Rep 1,442
yea, our old school pumps... I wonder what it would take to convert to these newer styles? Hardware, programming?
06-14-2021, 12:17 PM | #12 |
Rep 1,299
Probably gonna need wiring and a separate controller for controlling the pump. Or you can try the new ecu but probably gonna be a nightmare getting that working right.
06-14-2021, 12:19 PM | #13 | |
Rep 1,442
06-14-2021, 12:21 PM | #14 | |
Rep 1,299
Well it not just the tune. The software might be different and such could cause problems trying to tie everything to your car. Unless someone can make it all work without an issue. But in my experience it never works nicely. |
06-14-2021, 03:07 PM | #15 | |
Rep 1,442
What is available for the n55 with the old style continental brand pump? Is there a way to modify your current stage 2 to make it compatible? Please let me know. Thanks! --- Unfortunately we don’t have anything compatible with the N54 style continental pumps. In theory our kits would bolt up using a newer N55 vacuum pump housing, but the electronics wouldn’t have any way to control the system. --- Thanks- Is there a module off of the DME specific to this new style pump that could be added or is it a system a tuner could control? I am working with David Shoup and there are a lot of n55’s on the old Fuel pump that would love to get a solution worked out. I wouldn’t mind helping pioneer this as it would open up a new segment of business if we had a working proof of concept. Thoughts? Thanks for your time. --- The two systems don’t work on the same principles. Physically it’s a matter of swapping vacuum pump assemblies, adding a sensor that doesn’t exist, and driving an entirely different solenoid. Beyond that, it’s a complete overhaul of the DME logic to control it. It’s most likely far too big of a software undertaking to be worthwhile, but that’s beyond what we do. That’s probably a question for MHD. --- I asked DS his thoughts... and exactly what you said, if it's just less effort to go PI at this point... |
06-14-2021, 04:13 PM | #16 | |
Rep 1,230
E85 LINES/SENSOR-250 EOS Controller-800 TUNE-600 Motive Reflex-600 not that much all depends on where you get the parts from.
N55 GENERAL
06-14-2021, 04:16 PM | #17 |
Rep 1,230
Spoke to David and he said he will be doing the changes to the injectors. I ordered mines Last week. Waiting to break in the motor and do my 3rd revision before i drop them in. Only problem i worried about is if one goes bad... i have to have an extra as a quick replacement.
N55 GENERAL
06-14-2021, 04:18 PM | #18 |
Rep 1,230
I would keep your setup and run port. Plenty of N54s with that old school pump making hella power. Theres a 535i in Texas E series on a 6266 making 700+. Get the motiv reflex for extra safety and control the port.
N55 GENERAL
06-15-2021, 08:10 PM | #19 | |
Rep 1,299
+ bmp4 fuel module + port injection kit + motiv reflex + e85 line with sensor. Where did you get the line with sensor for $250? Spools is almost 400 dollars. 3k+ job lol then onto sending trans and torque converter to pure transmission for upgrade plus transfer case clutch upgrade/rebuild. Then upgrade axels to hold extra power from stop light launches lol before they bent. |
06-15-2021, 08:20 PM | #20 | ||
Rep 1,442
For clutch on MT 550 clutch is compatible and 300 bucks at fcp euro. I am going that route. |
06-16-2021, 01:42 PM | #21 |
Rep 1,299
I am doing the manifold route with fuel line that piggy backs off of main line coming from tank then split into hpfp and port injectors. For me being an auto would require more then just clutch upgrade.
06-16-2021, 01:46 PM | #22 | |
Rep 1,442
