2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Why isn't this bumper fitting correctly?
      01-18-2025, 02:26 PM   #1
AdamAA
AdamAA's Avatar
Drives: 2016 f10 528i
The fitment of this new bumper is so poor it’s made for my car and has a guaranteed fit do I return it or is there a way to fix this?
      01-18-2025, 05:48 PM   #2
I would return. That fitment is beyond poor!
      01-18-2025, 07:54 PM   #3
M_Bimmer
Drives: .
Your 4th picture shows that the bumper isn’t correctly fitted over the front air intake plastic assembly….its also the reason for the poor fitment shown in your 1st 3 photos.
There are two small plastic tabs on the aluminum cross member that if aren’t aligned, will cause your bumper cover to droop and not sit back enough for a proper fit.
Fit the front first, then tackle the sides. If you sit the bumper cover loosely on the front and try to fit the sides, it won’t go on correctly.
zrile153.00
AdamAA3.00
      01-19-2025, 11:37 AM   #4
M_Bimmer
Drives: .
Forgot to add, if you practice with your original bumper cover first, even if it’s broken, you’ll have better success fitting the new bumper cover.
You’ll find out that it’s easy to hang up on the front end and side hardware, and if that occurs, your bumper will remain “slightly” off.
If you have to pull the bumper cover back to force it to clip into the fende rails, the front is not on correctly….the bumper cover sides should snap into place with no force required.
      02-03-2025, 02:55 AM   #5
AdamAA
AdamAA's Avatar
Ended up js being a super poor fit and was messed up during shipping, I got a new one that fits much better thanks anyways!
      02-11-2025, 08:07 PM   #6
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
hard to tell with them pictures...maybe step back a bit on some of the shots
