12-22-2018, 10:35 AM | #1 |
El Conquistador
12
Rep 44
Drives: 2015 535i xDrive
Do I need hub ring?
New wheels have a bore difference from the hub of .54. Discount Tire is having trouble finding hub rings that small. What do you think? Will I need them?
They can have them custom made, they think. |
12-22-2018, 12:47 PM | #2 |
Rep 5,366
A half inch? Yeah, you'll need hub-centric rings to prevent vibration. I've had so much trouble with centering rings; from not the EXACT size to dissimilar metal corrosion; that I'll only put factory wheels on my cars.
12-22-2018, 02:07 PM | #3 |
Rep 14,521
ha you're just north of me! as far as hub rings like ezaircon4jc mentioned you'll get some vibrations without them. I would reach out to the wheel manufacturer and ask if they make hub rings for your application
12-22-2018, 02:15 PM | #4 |
El Conquistador
12
Rep 44
Apologies, 0.54mm, not inches.
Hub bore is 72.65mm, wheel bore is 73.10mm. I'm getting a bit of vibration. They've been balanced twice. It was better after second balancing but still a bit there. I hit a site for custom hub rings and they require at least 1.4mm difference, so I may be out of luck there. |
12-22-2018, 03:34 PM | #5 | |
Rep 5,366
12-23-2018, 11:59 AM | #7 |
Rep 14,521
well shoot! sounds like you bought the wrong wheels for your car. I would go back to whomever you purchase them from and let them know that this is not the right wheel for your vehicle and see if they will work something out
12-24-2018, 12:48 PM | #8 |
El Conquistador
12
Rep 44
After a third balancing, the wheels seem to be doing ok, so far. Wondering if I'll be ok with these wheels, or just asking for trouble. Discount Tire's 'fitment guy' says the wheels should be fine. Thoughts?
BTW, they let me know they are having issues with their balancers nationwide, in case anyone here uses them. Tell your shop to turn off 'Smart Balance' and use 'Technical Mode'. My shop also used a new wingnut as worn wingnuts can cause issues. |
12-24-2018, 01:40 PM | #9 | |
Rep 5,366
12-24-2018, 01:48 PM | #10 |
Rep 659
In my opinion you are asking for trouble.
You don't have the proper fitment. If you insist on these wheels i would think about going to a machine shop and have some rings made to take up same slack. Just an option. |
SonOfAnakin11.50 |
12-25-2018, 07:21 AM | #11 |
Rep 14,521
as mentioned above from ezaircon4jc and wcr3d heed what they say
12-25-2018, 09:37 PM | #12 |
El Conquistador
12
Rep 44
12-25-2018, 11:45 PM | #13 |
Rep 5,366
I'm partial to BMW's OEM wheels so I wouldn't go aftermarket. That said, I would only purchase BMW OEM wheels; from wherever I could. I would look at eBay, wheel web sites, any place that sells OEM wheels. I wouldn't be afraid of refurbished wheels, however, I'd be leery of repaired wheels.
SonOfAnakin11.50 |
12-26-2018, 08:19 AM | #14 |
Rep 14,521
there's many of us who go aftermarket and when I mean aftermarket I mean wheels specifically made for your make and model. that way hub rings are not needed. also, if the manufacturer allows you to, custom offsets are also the way to go that way you don't have to use spacers which there's plenty of debate on regarding hub bearing failures due to the stress the spacers put on them. I went with GetYourWheels which is a site sponsor. that's another thing, go with a site sponsor
SonOfAnakin11.50 |
12-26-2018, 04:09 PM | #15 |
El Conquistador
12
Rep 44
Returning the Discount Tire wheels and tires and heading over to the bmw dealer. Probably just put winter rubber my oem 19s.
