2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes 20x10 setup + fitment
      10-04-2019, 10:24 AM   #1
F10Jefe
Drives: BMW 535i xDrive
I'm looking to purchase new wheels and I love the look of the OEM M5 343 20x10's (or even aftermarket wheels). Is anyone running a 20x10 square setup on their front and rear wheels? If so, how is the fitment? Do they rub? I have a 2011 535 xDrive. I do NOT want a staggered setup. PLEASE HELP ME!
      12-16-2019, 09:05 AM   #2
~STREETDREAMS~
~STREETDREAMS~'s Avatar
41
Drives: 2014 335IX M SPORT SEDAN
Sent you a PM as you requested, Thanks
      12-16-2019, 09:09 AM   #3
F10Jefe
I can't reply to your PM because you have to clear out your inbox. It's saying it's full.
      12-16-2019, 11:50 AM   #4
F10Jefe
You need to delete more of your messages. I can't PM you again. Smh.
      12-16-2019, 12:45 PM   #5
~STREETDREAMS~
41
Sorry bud, Should be good now
      05-14-2020, 06:13 AM   #6
PapoF10
Drives: 2011 bmw f10 535i
Hey. Wondering how your fitment went. I want to run 19.10.5 square but wondering if it will be to aggressive for the front ?
      05-14-2020, 03:34 PM   #7
MatthewLC
Drives: 2011 BMW 535i
I have 20x10's all around on my car and the highest offset you'll likely be able to run on the front is around +30. Any higher and the wheel will contact the front hub/knuckle.
My wheels are originally 20x10 +40, but they hit the knuckle/hub on the inside of the wheel before I could bolt it down. I ended up running a 15mm spacer, which basically makes the set up a 20x10 +25. The wheel just barely clears the front knuckle with that spacer. I haven't measured the exact amount of clearance now but it's probably around 5mm or less.
      05-15-2020, 06:04 AM   #8
PapoF10
Nice. What tire sizes are you running. Do you get any rubbing in the front
      05-15-2020, 08:26 AM   #9
MatthewLC
I'm running a 255 which is a bit of a stretch on a 10" wheel. With the spacer the wheel sits about flush or maybe pokes out a little from the edge of the fender.
I rub constantly on the front fender liner on big dips, but that's cause my car is pretty low. I do have some rub marks on the inside of the fender lip but the strange part is I have no marks on the tire from it...
      05-15-2020, 09:50 AM   #10
PapoF10
So if I run with a 245 35 19 I should be able to make the fronts fit. Wheels are a 19x10.5 et22. I ordered bc coilovers extreme low. Waiting for them to come in to install and test fit the rim in the front. Do you have any pictures of your ride ?
